Dash lighting restor on '56Atom |
56-Atom
Groupie Joined: September-30-2018 Location: Dayton, OH Status: Offline Points: 78 |
Posted: April-05-2020 at 3:44pm |
1956 Atom is getting a full electrical restoration. Now looking at replacing the dash lighting. Any recommendations on venders for the vintage light harness, staying w/ original switch and 6volt system (in the hopes of "keeping it original". Or, options I can run off my 12v battery (set up for bilge pump)
56-Atom
https://www.facebook.com/media/set/edit/a.1729455880510267/ |
John,
Why the 12 volt conversion? For a bilge pump? Do you know 6 volt bilge pumps are available? BTW a plywood hull should not leak. The only water you should get in the bilge is from the drips of the shaft stuffing box. |
56-Atom
Not a 12volt conversion Pete. I am still running the 6volt system. Past summer was the first time she had been in the water since 1975 and I was a little cautious. I just added a separate bilge system of a 12v in the event the engine went out on me in the middle of the lake. (which did happen when attempting to set the timing)
So, "keeping it original" Any thoughts on the lights? |
56-Atom
John,
Why not keep the lights on the 6 volt and only have the 12 volt battery for the bilge pump? Do you have leaks in the hull? Again, 6 volts pumps are available. |
56-Atom
I hope to keep the lights on the 6v with original switch. Just need to rewire and looking for options on finding the connector base at the end of the run.
56-Atom
John,
I don't feel you will have any luck finding the bayonet bulb sockets. I'd suggest cleaning them up and getting some adhesive lined heat shrink tubing around the insulation area that's frayed. |
Would these work ? link
56-Atom
A simple fix that I did not think about, thanks for helping me "keep it original"
Finished work: |
56-Atom
56-Atom
Those might and will keep the link to refer to if my originals fail. Thanks
56-Atom
Maybe they would work for 2 if they fit into the same dia. hole. If won't work on the third (the one with the frayed insulation) because the bulb on the original goes deeper into socket. I feel there wouldn't be enough depth in the panel for the bulb and the reason for the deep socket. Gary good find. You're almost as good as Ken with your searching. |
56-Atom
Pete, good eyes...just for fun...can you guess what instrument the third one (larger frayed one) goes to on my dash?
56-Atom
John,
I think the third bulb goes into the center of a Stewart Warner panel lighting the tach. The other two are on the lower sides lighting amps, temp and oil pressure. I can't find my SW catalog plus my memory has failed me so I don't know the specific panel name. Did you get the oil out of the dash? |
56-Atom
You are correct on the smaller two lights, the larger one plugs into the back of the clock.
Still working on the dash, will post when finished. |
56-Atom
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
And Ken's only mediocre at best Like I've said before, match me up with pretty much any 13 year old with a cell phone and I'll lose every time |
56-Atom
Pete, after further review...I believe the clock was perhaps not original, as I do not see it listed in the original sales brochure. You are correct with the other two lights "other two are on the lower sides lighting amps, temp and oil pressure"
Thanks for playing the "guess that dash gauge" game! |
56-Atom
