Bilge wire has continuity but no power. I’m lost |
Author | ||
C_Heath
Senior Member Joined: January-21-2020 Location: NC Status: Offline Points: 207 |
Posted: April-20-2020 at 8:21pm |
Ok so I think it’s wrong to open another “I need help” thread while I have one open already HA!!! But I’m lost. 2000 pro air with GT40. The bilge is working because when I Unhook it and plug it into the ballast wire and hit fill on the pad it cuts on for 2sec like it supposed to to check if water is present.
Ok to the key pad. It’s BRAND NEW today. Got it in the mail thinking it was the pad. That was a $421 mistake. So when I hit the bilge button the pad, the green light cuts on and I hear a small tick under the dash. Just like when I hit any other button. My meter also measures continuity by alarm and the bilge plug has continuity but when I switch it over to volts I get nothing. Also, all the breakers under the helm are good shape and not tripped. Does anyone have the slightest idea of what I can check next.? Yes I can run the bilge off of the ballast wire just fine but it will only run the front pump and I spent 8 hours putting a new pump in the rear back in March and I just want everything to run like it’s supposed to. Dropped a load on this thing and it was all I could afford. Nice boat but I am certainly Busting Out Another Thousand quiet frequently lol Thanks again guys! Chris in NC |
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold) 2000 Pro Air Nautique/GT40 |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Have you checked power at the bilge pump with the switch on to a known good ground (maybe back to the battery or engine block)?
My 95 uses 2 Atwood pumps and a Water Witch switch like one of these I suspect yours will be similar or maybe the pumps have a built in switch? Fill the bilge and see if it turns on. I do know you have to wipe the switch off every now and then if you have a dirty bilge
C_Heath
The entire keypad is sealed. I can’t get into it. It plugs into a 4 pin plug at the helm. |
C_Heath
When I unplug the non powered bilge wire and plug the actual bilge pump into the ballast wire (that reads 12v on my meter) the pump starts running. |
bfootr
Can you check voltage at the connection at the bilge pump? If you can and you don’t get any voltage, check it again with the negative lead from your meter to a known good ground. You can call me if needed (especially since you’re a fellow NC’ian :-) if needed. 919-464-9137. -Gene
How did you check the breakers? For voltage in and out with the VOM? |
C_Heath
Also my pump is automatic. It checks for water in the bilge every 5 minutes and knows if it’s there by amp draw. If the draw is higher because of the load, it continues pumping water. After 5 nite minutes it checks again. No float switch. |
C_Heath
I’ll do that tomorrow. If not I’ll call ya! Thanks lol |
C_Heath
I didn’t open the breaker box. It said not to. I just checked to make sure they weren’t any tripped. |
