  New Posts New Posts RSS Feed - Oil level / Dipstick
Tomahawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Topic: Oil level / Dipstick
    Posted: April-24-2020 at 2:13am
I have a 76 SN with a 351W. The dipstick does not seem to fit right. There are two scribed marks on it above the normal add / full marks. Can someone give me the measured length from the top of the tube to the fill and full marks? is there an aftermarket dipstick that will have the correct levels on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 5:50pm
so the picture shows the dipstick with the two marks that look like they were added.
detailed picture shows measure of how far from the top of the tube. I am also concerned that the top of the dipstick doesn't cover the tube. shouldn't there be a little sleeve that slips over the top to seal out dirt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 6:19pm
From the CCfan FAQ tread in the maintenance section:
Gary's test on oil pan capacity
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 9:31pm
Tomahawk
I'm assuming your engine is a PCM 351, if it is the below info might be good. If it's a Commander 351, it probably won't work for you. Based on your numbers it should be a PCM, the Commanders had a lot longer dipstick and tube than yours.
the link is to one of those "other" websites with some good information about a 351W mounted at an angle like yours is complete with measurements of the original dipstick like you're looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2020 at 11:01pm
it is PCM.
Thanks
