Oil Temp Sensor/ Oil Pan Bung Placement |
DHMcFadin
Senior Member Joined: May-27-2019 Location: Austin, Texas Status: Offline Points: 312 |
Posted: May-20-2020 at 12:02pm |
Morning,
If anyone has a gt40 in a Ski/Sport/Air, I was wondering if I could get your opinion./ measurements. I want to add an oil temperature sensor to my Holley efi system. The thing is, I dont have the engine in the boat to check clearances. I would like to add the oil temp bung on the port side of the oil pan, down in the sump. Maybe right next to the remote oil drain bung? But I want to ensure there is enough clearance between the oil pan and all other components/mounts/etc. Could anyone take a look for me? The temp sensor would only protrude about 1" plus the harness plug. Thanks, Dom |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
Based on my Ski (2001 year) there appears to be adequate room on the port side next to the oil drain.
JQ |
DHMcFadin
Perfect, thank you!
