Holley inlet fitting |
Posted: May-22-2020 at 6:37pm |
Does any one know what size thread is on both ends of this inlet fitting?
I know the one side is a flared fitting thread but what size and the part that screws into the carb base, what size? TIA Inlet fitting |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
7/8-20 and 5/8-18
Must be price shopping |
If you're good you can get three for the price of that NP one
Then again.......................If you're real good you can get 4 And..............if you're really really good you can get 5 |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2822 |
Actually what I was thinking is... Is there a 90* fitting available That can work in the quick fuel 600 and still use the original solid fuel line.
That's a totally different question Lotsa luck |
The closest you could get is to use a inverted flare 90. |
Thanks Pete I was just thinking if you could find a fitting like this in a 9/16 x 9/16 then go with the stock fitting from there.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
If you’re trying to save a few dollars, grab a couple Edelmann 821660 and some A1 hose + clamps.
Duane in Indy
The closest you could get is to use a inverted flare 90. Pete, That looks like a standard hydraulic hose fitting. That would require hydraulic hose which would also require a similar fitting on the opposite end. They also need to be crimped on by a hydraulic crimp machine. I had a machine to do that with when I had an excavating company but sold it with the equipment, very costly. Guess you could have a hose shop make them for you. |
1978 Mustang (modified) |
