water pump gasket |
99airwarrior
Senior Member Joined: August-19-2019 Location: Reno Nv. Status: Offline Points: 141 |
Posted: May-29-2020 at 1:16am |
1985 2001 351w I can not find the right water pump gasket. This is the pump to plate I purchase the whole fel-pro Timing chain cover gasket kit TCS45449 and it did not come with the above gasket. So I went on line and the only one that looked like it would work was a fel-pro 35214 had it shipped and it had one bolt hole off. So I know people at Ford,Napa,O"Reiley"s we looked through the computes, their was only 1 other gasket available and it was way off. So I purchased some gasket material and made my own. I should have taken a picture of the pump before mounting it so I could post it, I wanted to know if anyone else has seen this problem? I did check all years of 351w,400 block,ect. the pump gasket was the shape of a football just like the fel-pro 35214 the package say's 351w eng. 1979-86 Thank You
99airwarrior
Gary that one is way off from my pump look at the fel-pro 35214 it looks just like the one in the picture except one bolt hole completely is off of the pump all the rest line up Joe
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11119 |
Hi Joe
Here are a couple pictures First one is what your pump probably looks like with the cover removed. You can see the black gasket still stuck to the pump. It's a mid 80's bi directional pump. Second picture is a FelPro who's number is 35019 like Gary mentioned . If you lay that on the pump and trim it with your favorite razor knife where I drew in the silver lines, you end up with a gasket that fits. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
KENO:
I'm always amazed at the quantity and diversity of engine photos you have -- seemingly at your fingertips. You are the "Rainman" of the marinized SBF. JQ |
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
Quality auto parts store sell good gasket material too
You could easily trace and make one |
99airwarrior
I Do not know how we missed it we pulled the gaskets and laid them on the pump. I must have made a mistake Thank You everyone for the help Joe
99airwarrior
Keno Thank You for all effort with the exact pump picture Joe
A quality reading job would have told you in the first post that Joe bought some material and made his own gasket It probably took a little longer than trimming the one shown above.though. |
No problem, it was laying on a shelf,along with that gasket And JQ, I'm more like the 351W junkman |
67 ski nat
I need reading glasses. I’m holding my phone 3’ from my face
Sorry missed that. Just trying to help |
