GT40 oil pan hose washer cracked |
Canuck-Surfer
Senior Member Joined: September-14-2019 Location: Ontario, Canada Status: Offline Points: 222 |
Posted: May-30-2020 at 12:46pm |
While putting the drain hose back onto the oil pan during the GT40 rebuild, I over tightened the elbow connector that screws into the oil pan and cracked the hard plastic washer. The boat is sitting in the driveway while I work on the gelcoat and waiting to get the transmission put in. I've had some oily residue coming out of the hull drain port that I first thought was just from a dirty bilge, but I got in last night and discovered oil is leaking out of the oil pan at the drain hose elbow.
Does anyone know the specs on the plastic washer? Can I just take it to my local auto parts store and find something similar? I don't even see it listed on Skidim. Thoughts? |
1996 Sport Nautique GT40 EFI
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11113 |
Do what you just said, take it to the local auto parts store and they should be able to come up with a replacement rather easily |
Canuck-Surfer
So I found the oil hose kit on Nautique Parts and in the picture of the kit it showed a metal washer with a rubber inner ring. Went to the local auto parts store and we found a Dorman kit of 2 oil plug washer with integrated gasket. For anyone else looking its Dorman part 65274. Picture attached. Also...it can be found on Amazon but for 3 times the price as the local auto parts store!
