Engine Rebuild Interval Thread |
Crmaverick ![]() Senior Member ![]() Joined: July-06-2019 Location: Central MA Status: Offline Points: 190 |
![]() ![]() ![]() ![]() ![]() Posted: June-03-2020 at 12:02pm |
Here’s a thread to post how many hours everyone putting on their engines before rebuilding. How many hours can you typically go before needing atleast a hone job and piston rings?
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
There are a lot of factors to consider, not just hours. I’ve seen many well-maintained marine engines that have over 2,500 hours in a ski boat application.
Long hours at high RPM can shorten shorten Life. High performance mods and higher compression ratios can also impact engine longevity. You can run a top-end rebuild if the pistons, mains and rod bearings are OK. You could squeeze out some additional life that way. JQ |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
Any symptoms, or you just want to stay ahead of it?
Its summer, not the time to take it apart! That engine has been apart before, correct? Its sister boat has over 2000 hours, never apart. an indmar mastercraft i know got 3000 hours before it fragged. Leakdown test would give you a barometer of its innards' health. |
River Rat to Mole |
Orlando76 ![]() Grand Poobah ![]() ![]() Joined: May-21-2013 Location: Mount Dora, FL Status: Offline Points: 3108 |
I have a boat I bought with 383 hours on it, super clean, but 1 cylinder was low on compression which made engine run rough. Replaced that motor. I have another boat with over 3000 hours on original 1975 Waukesha. It’s getting tired, holeshot is getting longer, top end is still reasonable but that 3000+ hour motor runs so damn smooth and clean, until it fails we can’t justify touching it. Maintenance plays a part, luck plays a bigger part.
DVskier ![]() Senior Member ![]() Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
I have a friend with a 1998 Malibu with 4,20o hours. Other than replacing a low pressure fuel pump and regular oil changes, raw water impeller the engine has never had a wrench on it. Of course he runs only non ethanol fuel (that many forum members decry as “unnecessary”). The key is he runs the boat regularly and pays attention to engine temperature, oil level, etc. He has owned the boat since new.
For sure, I wouldn’t pull it apart for a few more seasons at the earliest and during a winter. I was curious and wanted to stay ahead of it, approaching 900 hours. The engine hasn’t been apart before according to the second owner. It does use about a half quart oil every 10 hours or so. Do you know if the sister boat uses any? I hear that hi po motors can tend to do that with loser tolerances. Also valves seals are going so that contributes some. I got a bore scope and took some cylinder pictures attached, looks like typical cylinder wear. https://drive.google.com/file/d/1ev9DsNqHkNCnbr8BBm85oDaWZiSjtfFe/view?usp=drivesdk https://drive.google.com/file/d/1YFLxg_eWJm1xvcj8Dbw2qUP0f0t5qmcu/view?usp=drivesdk |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3778 |
My 1978 Nautique ran 1,100 hours before it started fouling one spark plug regularly. Turned out it had one burnt valve not sealing any more. We installed just new heads, switched to some old 289 HI Perf heads that had been ported and polished with larger valves installed. A friend who was heavily involved in racing offered them to me. They pumped up the compression having smaller chambers and that old 351W had a lot more power than ever. Did not use any oil between changes.
We sold that boat at 1,600 hours and it was still running very strong. After 1984 or so the new boat engines were built with Moly top piston rings. They are much softer on the cylinder walls causing much lest wear, probably doubling the cylinder wall life. Keep it tuned up and enjoy it. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11189 |
Hey Mav
I heard a rumor that you got your Delco EST distributor issues ironed out ![]() |
I did that advance curve was no good, tried two modules. The new Davis distributor has a perfect curve |
