Rh distributor help |
Post Reply | Page <12 |
redtoybox
Newbie Joined: August-23-2016 Location: Knoxville, TN Status: Offline Points: 26 |
Sorry it took me too long to reply. I gave my '73 Nautique to my son many years ago. He has used his mechanic to work on the boat engine (I think he's good). We have put a new carb, new plugs, and new points in. The mechanic says the distributor rotor cap easiiy turns 360' when holding the gear shaft from turning. Bad shaft?
The boat runs OK to 20-25 mph, but misses badly trying to go faster.
d*ck, Could be a simple as a sheared pin holding the gear to the shaft? Maybe he could tell you more? If not, I'd certainly get someone else to take a look at it before condeming the distributor.
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10650 |
d*ck
On your Mallory there's a fork that screws to the advance plate and keeps the points cam in position on the plate. if he's spinning the rotor 360 degrees he's either Hulk Hogan or the fork is loose. It's hard to visualize and harder to explain. I could post some pictures tomorrow if you want. It sounds like he's doing this while the distributor is out of the engine and the movement will have the timing all screwed up if he tries to just randomly position the cam and tighten the fork unless he gets real lucky. It also sounds like a new coil would be worth trying. |
And I missed the new carb too. Sounds like Hulk Hogan likes to just through parts at a problem? d*ck, Seriously, is there someone else that can look at the problem? |
redtoybox
I'm having a problem posting my replies since they are not going through, but I'll try again.
Re the gear being loose from the shaft; that's not a problem. I have convinced myself to get a new distributor, but having a problem finding the correct one. I went to summitracing.com . My Mallory is YL 555DV for a 1972 Ford 351W. There seem to be several, including an inexpensive one, Proform Pro-66983B for only $144.99, which sounds too cheap. There are others, but don't know what is correct. My Mallory has a gear shaft of .531 and a shaft size about 1 1/2" where it fits into the header. |
redtoybox
Sorry I'm late in replying, but yes, I would appreciate your pictures.
Please send to 865-300-9917 Thanks
Pictures later today or tomorrow, I'll put them in this thread.
redtoybox
OK,but not sure I can get them. I would like to forward them to my son's mechanic who has worked on the engine, so I would appreciate it if you could send them to my wife's phone (865-300-9917).
Thanks
Hi d*ck
2 pictures and a short explanation texted to your wife's phone
Here are the 2 pictures
Top one shows the fork that holds the cam to prevent it from rotating in the center hole removed and the cam can rotate 360 degrees with some force applied to it. Second one has the fork in place and tightened down so it won't move in the center hole..............unless you turn it too hard, then it'll move Hope this helps
redtoybox
Than you very much!
