  New Posts New Posts RSS Feed - 79’ 302 commander Water pump
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Topic: 79’ 302 commander Water pump
    Posted: August-23-2020 at 1:10pm
Fresh water impeller was shot. Replaced for the second time in 6 years but the kit doesn’t come with the correct gasket. Tried sealant but leaks. Metal plate inside has some wearing but not terrible. Is there a affordable replacement pump for these?
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2020 at 5:13pm
Pictures please
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2020 at 5:25pm
Eric,
Have you been ordering the kit specific to the model of the pump?
Also, never run the impeller dry since they are water lubricated. I've even see impellers blown at the ramp when someone has started their engine before the boats in the water. It's the "we had better see if the engine starts before we put the boat in" senerio.
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2020 at 8:04pm
Read the adding pics instructions but I don’t see any tree in a toolbar to click.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2020 at 8:52pm
Read them again. You need to click the full reply icon first.
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2020 at 10:03pm
The kit I use is Jabsco 1210-0001-p. Impeller is correct, worked last time but every other part the kit comes with isn't.
Apparently you can't select full reply or get the add pics options from a phone in either display mode..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 6:52am
Eric,
Do any of these gaskets look correct? I found them listed on Amazon by using your impeller kit # and doing a search. If not, cut your own. Also, you may want to pull the pump shaft for new bearings and especially a new seal. They are common power tranmission components and not specific to the pump.
Post Options Post Options   Thanks (1) Thanks(1)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 12:18pm
Looks like our pump and the gasket is more triangular. We had to cut new ones. We grabbed gasket paper at the auto parts store and used scissors and an exacto knife. Takes a little time but you will be back in action once done. A hole punch/die would be awesome for the screw holes.
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 12:56pm
The pic of gaskets is what my kit came with. They’re all missing just enough material to make them not modifiable. I guess I’ll make a gasket. Is there not a new pump option for these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 5:30pm
Eric,
A bad shaft seal could also cause the RWP not to work too and the reason I mentioned it.
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 7:18pm
Thanks. Oh you mean like why it didn’t suck water when I first started it because the seal provides aN air leak. I dunno, I smelt it burning within a minute.didnt leak last year. Still can’t believe for such a simple pump there’s not $50 New option available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 7:43pm
Did you lubricate the new impeller when you installed it? Where have you been looking for a alternate pump? The worst is you would need to do some minor plumbing/hose changes.
Gump View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gump Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2020 at 8:22pm
I’m sorry I smelt the old one that failed. The new one that leaks because of no good gasket, yes I lubed it.
I googled a few for the boat and only $400-$500 pumps popped up.
