Wake shaper compatability with 2001 hull? |
Wilhelm Hertzog
Posted: September-25-2020 at 4:39am |
I'm looking to get a wake shaper, but am concerned that not all designs are compatible with the hull of my boat (1982 Ski Nautique 2001). I emailed Liquid Force about their Wakesurf Edge and was told that none of their shapers are compatible with the 2001 hull.
Anyone with experience/recommendations as to which shaper will work best?
You can make one for about $20. Search the 'net, probably find the design on planet nautique. I had made one, worked good. It uses a dent puller suction cup, get at Harbor Freight. Also a cutting board - Walmart. Mine never came loose but had a tether on it just in case.
Wilhelm Hertzog
As described in this thread?
That's it, but use a HDPE cutting board (walmart) instead of plywood.
rolleronariver
Senior Member Joined: May-24-2016 Location: Rogers, AR Status: Offline Points: 195 |
I made ours too. I actually got on amazon and ordered a 3/4 inch thick cutting board to make it more durable. The whole thing cost under $30.
92 Sport nautique
Wilhelm Hertzog
Do you have a picture perhaps? Did you use 90 degree brackets to fix the cutting board to the suction cups, or do you have a different angle to lessen resistance through the water when under way? |
rolleronariver
I don’t think I have any pics but I’ll take some next time I’m at the boat storage and post them. I used about a 60 degree angle to lessen the force. I’ll try and get the dimensions for you in the next couple of days. Ours works very good!
92 Sport nautique
Wilhelm Hertzog
I ended up using a 40cm x 25cm x 1cm cutting board and suction cup handle both bought off the shelf from a local online retailer. Couldn't find any 60 degree brackets off the shelf, so I had a local welder make two stainless steel ones for me. The plan was to use pieces of pool noodle around the stays of the brackets for bouancy, but that didn't provide enough flotation, so I used a tether rope attached to the swim platform in case the suction cups detached from the hull. The setup worked well over the past weekend, never had any detachments. I still need to experiment a bit with placement of the shaper on the hull, but so far so good. All in all probably cost me about $50.
fahtal
Groupie Joined: August-31-2020 Location: NL Status: Offline Points: 42 |
we made the same style wakeshaper it is not 90 degree anymore. more 70-80 bending over backwards. we attache at the end of the 2001 decal. the decal messes up the suction some times.. with some guys in the back for ballast we can get a decent wave and ride ropeless. sometimes we take some sandbags with us. we should put more ballast in but are still looking for sollutions for that.
nobrainsd
Senior Member Joined: August-13-2015 Location: San Diego Status: Offline Points: 157 |
Here is another example of a DIY wakeshaper. Using the same HDPE for the side supports was really easy. I used two binding barrels and screws to hold the suction assembly in place so there isn't any rough surface to catch your hands on. If you make a wakeshaper you might want to remove the suction cups and replace the springs and fasteners with stainless so you won't get rust. I used a little corrosion x on the center plunger that I couldn't replace. Otherwise be sure to burp any remaining water out of the inside of the cup bodies when you are done for the day. Rust never sleeps!
Surfing is fun, but if you want to have a great ride with less ballast and a small wake you should try wakefoiling! I ride behind my Ski Nautique with very little wake. It is so much fun. We even ride the second wake. Foils open up a surf style of ride on a lot of boats with poor wakes and are really a gas behind my buddies bigger boats with surf gates. We peel off and poach/ride wakes well back off the bigger vessels that transit our bay. Wakefoils will catch almost anything! |
rebel skier
Gold Member Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 771 |
I really want to try one of those foils but damn if they are nearly as expensive as my boat :)
nobrainsd
As the more the serious foilers transition to lighter carbon set ups I see more older set ups with aluminum masts, compression molded boards and composite wings being sold for pretty reasonable prices. The trick is to not buy wings that are really designed for kite boarding or primarily designed for paddle in foiling. I ride a middle range set up from Liquid Force. Certainly not as light as the Armstrong set up my friend Jimmy is riding in the picture in the post above, but very much fun and more beginner friendly. Watch Craigslist and you may find what you are looking for. here is an example of good wakefoil wing. It is a higher aspect ratio wing and has a 1250cm surface area. Great in the first wake and decent on the second. Much smaller and it is hard to drop the handle and free ride. Lot's of companies making wings with similar size and aspect ratios.
I don't want to derail this this thread, but since I see friends going to great lengths and expense to add a ton of ballast to get a decent wave I had to toss out how nice it is to have a fun ride that is hassle free. Jimmy is on Facebook as Jimmy Jam Foils. Check out his posts. Wake foiling, tow in wave riding, paddle in surf foiling and electric foils. He does it all. Loads of videos and he is happy to be of assistance. Now, sit down hydrofoils are really fun and I can jump higher than I want to go with no wake, but those CNC'ed billet wings and struts are really big bucks! |
