Winterizing 79 Ski Tique??? |
crooney70
Newbie Joined: May-10-2006 Location: United States Status: Offline Points: 20 |
Posted: October-09-2006 at 8:37am |
Anybody have any good advise on hoe to winterize my '79 Ski Tique with a PCM 302?
Thanks |
"Rooney" on Tippy
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Online Points: 6098 |
some tips
some more tips Take a look at these. If you have any particular questions after that, ask away. To summarize gas tank at or near full, add stabilizer run fogger through engine drain water from block remove plugs, spray fogger or WD40 into cylinders, replace plugs pour or pump 2-3 gallons antifreeze into engine some folks change oil for winter light coat of wd40 over whole engine |
I always remove my water pump and impeller as well. Dont forget to empty the strainer if you have one.
Did your ebay deal fall through? |
crooney70
"Did your ebay deal fall through?"
Yes, I geuss I will just keep the boat until spring. Thanks |
"Rooney" on Tippy
