  New Posts New Posts RSS Feed - Foam Density Question
dip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dip Quote  Post ReplyReply Direct Link To This Post Topic: Foam Density Question
    Posted: March-15-2021 at 5:08pm
I am going to repair some wet foam. What density is better to use? It is available in 2lb or 6lb from Jamestown Distributors.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2021 at 5:27pm
The 2lb. is what was used. The primary purpose is flotation and the reason for the lighter foam.
dip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dip Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2021 at 5:52pm
Thanks Pete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2021 at 6:00pm
Read instructions of your 2lb closed cell
The foam I used was also dependent on temperature. Warmer is best(80) little more expansion for more flotation
Cold weather (50) probably tighter less floatation
Disclaimer: poster shall be held harmless for crapping info
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2021 at 12:32pm
h
Thanks
More important than the density of the foam is that it be closed cell foam. Meaning that there is no interconnection between the cells of the foam.  Open cell foam is like a sponge; water can travel from one cell to the next.  Open cell is almost gone off the market, but make sure.
"Art"
dip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dip Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2021 at 9:50pm
Thanks for the replies. Definitely waiting until it warms up a bit more to do the work, and no open cell sponges for me! Looking forward to getting started on it.
