  New Posts New Posts RSS Feed - Water Gushing Out of Bell Housing
willice0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willice0 Quote  Post ReplyReply Direct Link To This Post Topic: Water Gushing Out of Bell Housing
    Posted: May-16-2021 at 12:08pm
Hey guys,
In preparation for launching our 86 Martinique this weekend here in Northeast Georgia, we ran the engine in the driveway with the Timmy T (thanks for the great build info!). After running it for a good bit while we were adjusting the dwell, a gushing leak began around the bellhousing between the engine and the transmission. From my research here on CCF, as well as a few other 351W enthusiast forums, I've surmised that water has corroded through the end of the block from the water jacket into the bellhousing. Thankfully, this happened in the middle of the driveway and not the middle of the lake! It was a ton of water gushing out into the bilge.
My questions:
1) Is there anywhere else that water could be entering the bellhousing? It is definitely not a redirected small leak from somewhere else. It surges with the RPMs of the engine based on the throttle--small trickle at idle, increasingly gushing under higher RPMS.
2) I read on another forum that someone had drilled out the hole in their water jacket, tapped said hole, and then put in a bronze plug. Anybody have experience with this and want to talk us out of trying it? Wink My Dad is a large factory equipment repairman, so we're not afraid of doing some fabrication work if it might solve our problem.
We've mostly resigned ourselves to buying a remanufactured 351W Marine reverse rotation long block and dropping it in ourselves. Unfortunately, they seem to be in short supply these days. We have calls and emails out to several places (Rapido Marine, Atlantic Marine, MABBCO, Carolina Marine Engines), but Summit and JEGS both said their suppliers are currently out of stock and have no idea when they will have new stock. Cry We're not afraid of just buying a short block and reusing our existing reverse rotation parts (Dad has rebuilt two 351Ws in the past), but we can't even find one of those at this point.
Another question:
1) If you were going to mostly build a new 351W engine from the block up, what would you say are worthwhile upgrades/customizations? This is the moment to make changes, so I'd appreciate any input you have. Atlantic Marine will do a GT40 head upgrade for $400. Worth it? Assuming we might need a different prop to handle the extra power. We're not footers, so we might not even need the higher performance. Most of the shops either sell a black or a crusader blue block. Still trying to decide what would look better. We could always repaint with silver once we receive the block as well.
Anyone have a 351W reverse rotation in great shape just laying around in their garage that they would like to get rid of ? </SARCASM>
Thanks for any help or advice you may have to offer!
P.S.: Here's a pic of our Martinique after we cleaned, brightened, sanded, and sealed all of our teak. Lots of elbow grease, but totally worth it in the end!
'86 CC Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2021 at 3:13pm
Sounds like your research tells you that there are no plugs back there that could pop out, which is true, so the only thing back there under the bell housing to break is the block itself
Not knowing how it was winterized, it could have been from the colder than normal temps this past winter in the south causing the block to crack. In other words you can hope it's a little hole like you're talking about, but it may be a big crack.
No real good fix unless Dad's a stitch welder and even then, you don't know if there's another spot leaking or just waiting to leak internally or externally.
Take it apart enough to get the flywheel off and see what you have but don't expect it to be good. Wink
If a new short block is your route, make sure you read about reverse rotation crankshaft seals. Your 86 should have a 1 piece rear main seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 12:13pm
The 351w doesn’t have any casting plugs in the back? Could have sworn the 302 did.
Edit, google says I’m probably mis remembering. Have had a lot more bbc’s open recently. You may find something like this once you pull it apart…
https://www.correctcraftfan.com/forum/forum_posts.asp?TID=34178&title=302-with-water-leak-from-bell-housing-milky-oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:00pm
Tim,
From the thread you liked, is this the core plug you remember?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:22pm
Well that would be the core plug for the cam, not a water jacket… so no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:25pm
And here's a freshly taken bare naked picture of a 351W rear end.............. 4 plugs whatever they're called all on the oil side of things. Wink
Same for a 302 like the previous picture
Magically rotated 90 degrees by CCF
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:27pm
That is a nice window in the back of that block.  I had no idea the block was weak back there on the 351W.
