  New Posts New Posts RSS Feed - Sport/Air Trailer Dimensions
Big C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big C Quote  Post ReplyReply Direct Link To This Post Topic: Sport/Air Trailer Dimensions
    Posted: June-29-2021 at 11:19pm
I wonder if anyone could tell me the distance from the back of the trailer to the rear axle on a tandem axle trailer under a say 1997 - 2002 Air or Sport Nautigue. Also the distance between the two axles would be helpful.
 The single axle trailer under my 1998 Air is rusting into oblivion and I have procured a used tandem trailer that I will modify to fit the Air.  I need to establish where the stern of the boat should be located relative to axles in order to get the tongue weight at about 10%.  The trailer I will modify is now configured for a deep V boat so I will add some length to the frame rails behind the axles and build a new rear cross frame with the appropriate clearance for the prop and rudder.  It is possible that some lengthening of the frame rails forward of the axles will also be necessary but remains to be seen.
Thanks in advance,
Bruce
