  New Posts New Posts RSS Feed - 1988 Ski Nautique Runs Rough at Low End, Stalls
ccfan_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccfan_nc Quote  Post ReplyReply Direct Link To This Post Topic: 1988 Ski Nautique Runs Rough at Low End, Stalls
    Posted: August-28-2021 at 4:58pm
I searched as much as I could to find help I needed.  Apologies if I'm duplicating an existing thread.
I've owned this boat for 8 years.  It's been only in the garage, oil changes regular, winterizing, etc.  2 other owners before me according to the last seller.  1050 hrs.  It's been a center point for my kids thru their teens and so much for for us.  Big smile  This is background on the general condition of the boat.
Anyway, over the past month the boat has had some trouble starting up.  I have an on-going electrical issue with starting which I won't go into (yet) but this is a crank-crank-crank but no catch until finally it just catches and will run but we have to keep some extra throttle on at first.  Once we've warmed up it would do ok.
Within the last 3 weeks it started to run rough also while we were towing skiers, etc., mostly on the very low end and would sometimes stall while idling.  Once underway (higher throttle) it would basically behave.
Trouble starting but then running ok at higher rpms sounded like it could be a fuel issue.  It's been 3 years since I replaced the fuel filter so I made that replacement and I also cleaned the stator and tips on the distributor (last night) -- they weren't all that dirty.  This morning at the lake it practically jumped into action as though all our miseries were behind us.  As I celebrated during with our early am glass runs today, the rough running returned (about 60 minutes into the trip).  Before we pulled off the lake, the boat had stalled twice on us again.  So whatever good I did swapping out the fuel filter and clearing the tips had no permanent effect.
Other things I've thought of:
>>Spark plugs and wires were changed in 2019.  Haven't checked plugs again yet
>>Fuel bad?  Should not be -- running high octane non-ethanol unleaded fuel with no stabilizers or lead additives
>>Fuel pump?  Maybe.  I haven't checked the pressure but just replaced the sight tube and nothing obviously amiss plus it runs ok at higher rpm
>>Carburetor?  I've done nothing with this since I purchased the boat except 1 dose of Sea Foam in 2019
I tried reading thru the engine service manual -- some good ideas in there but many require special tools.
Other (concurrent) problems:
>>Boat occasionally will not turn over at all mid-trip (when it's hot).  Sometimes replacing the solenoid makes a difference.  This seems to be an electrical issue because the battery remains pretty strong
>>Slow oil leak from valve cover gaskets but we keep it topped up -- maybe because the engine expects leaded gas and we have been doing only unladed
Thanks for any insights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2021 at 5:50am
I'm wondering what you have under the distributor cap, points or an electronic module.
You mention that you cleaned the rotor and cap terminals, but if you have points that need some cleaning, adjusting or replacement) that would be a good place to start.
Or get a tuneup kit with cap, rotor, points and condenser..............or get an electronic conversion kitand a new cap and rotor.
Next I'd probably be thinking about taking the carburetor apart for a cleaning/rebuild.
Oil leaking from the valve cover gaskets...........you could tighten the bolts a little or you could preferably replace the gaskets. They're old and tired of doing their job Wink
Tightening too much on the bolts can warp the valve covers
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccfan_nc Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2021 at 12:49am
Sorry for the delays, I'm a weekend boater these days.  Thanks for the help!
If I pop the two screws on the distributor cap, I see 8 spots in the cap ("terminals"?) and a rotating arm on the bottom with a spring contact connection to the top.  Is this points or could it still be an electronic module?
If it was the carburetor, why would a fuel filter and rotor/cap terminals give it a brief clean-up?  Not debating, just thinking out loud.
Taking apart the carburetor...can I hack like me try that or do I need some long experience?
I need a special socket ot get to those valve cover nuts without pulling the water jackets or do the jackets have to come off in that job?
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2021 at 7:39am
J,
If you have a point set in your distributor, it will look something like this:
If it has the EI then it will look something like this:
Post a picture of the distributor with the cap off and we'll tell you more.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2021 at 3:28pm
It sounds like you haven't touched the carburetor since you've had the boat so if a general ignition tuneup doesn't straighten you out, it's time for some carburetor luv Wink It can get gummed up,crudded up with junk etc even with a filter in the system
Right now, only you know if it's got points or an electronic module. If it's got points and you don't know what they are, they probably need some luv too.
You can get a whole points tuneup kit with points, condenser, cap and rotor or just a cap and rotor depending on what you have.
Valve covers can be removed with the manifolds in place with a 1/4 inch drive socket set and a variety universal joints, flexible extensions etc and you'll probably drop a bolt or 2 along the way.5 out of 6 of the bolts are easy The lower center bolt, well that's a different story.
Putting them back on is harder, because of that same pesky lower center bolt on the valve cover.
Pulling the manifolds can present a whole different set of problems if the mounting bolts are in bad shape or rusted in place
As far as taking the carburetor apart, a rebuild kit with all the appropriate gaskets and replacement pieces is good to have on hand before you get started.
There's a list number on your carburetor that will help to get the right kit.
Here's a picture of where to find the list number (on the front of the choke horn)
You could start with the ignition system and move on to the carburetor if necessary
