1964 Dunphy (or other) stern light base |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 886 |
Posted: March-08-2022 at 7:13pm |
Trying to find a stern light pole for '64 Dunphy. Base has 3 mount screws, 2-pin light base, knurled tighten knob. Only markings on bottom are "CA 6224-04". Tried a Perko mast-too loose, and pins don't line up. Any ideas?
(will try and post photo) |
1994 Ski Nautique "Riot"
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7948 |
That looks like a "Jetson Stern Light" base. Keep an eye on ebay. They come up. Most that I have seen did not have the removable pole, but the pole receded into the deck. I've seen some for sale with the removable pole that had a square base. If you have room below deck for the pole to recede, you may be able to convert yours if you cannot find the type you have.
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 235 |
Definitely an Attwood base. Pretty sure you’ll find one but they may be expensive. I’ll keep an eye out.
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
MourningWood
Fellas, thank you so much. Riley, that looks exactly like my photo. I do have the base (in photo)...but never had the lamp portion. I don't think it 'retracts', as the fuel tank is just below deck.
I'll check e-pay and elsewhere...and thanks again!
h2oproofer
Newbie Joined: May-17-2010 Location: Alabama Status: Offline Points: 4 |
Did y ever finish dunphy emblem project? I am in need of a set
MourningWood
I'm happy to report...yes. The emblems have been signed off (by me) and are at chroming. The Dunphy scripts and both sides of the "flag" logo. (They each wave astern). They will come with adhesive-backing since we didn't want to drill holes (that may or may not line up). Hole can be drilled if preferred. Should be ready in about 3 weeks.
Also, I did find a correct rear stern light pole. Thanks Tell us about your X...
MourningWood
and, where has Pete been hiding?...
h2oproofer
I have a 63 and 64 dated dunphy
I know they say 64 was first year but serial is 63- The 63 has new wood bottom, rebuilt 312 original, new upholstery w proper stitching in lines. Multi year restoration a little here and there About ready to start the second boat but will be short a set of emblems Reason I was curious about yours. Would love to see when done and be interested in how to get a set made as well. |
MourningWood
h20proofer-sent you a pm
