'78 pcm 351 front view pic anyone? |
NeilMcG
Senior Member Joined: September-20-2021 Location: Pittsburgh, PA Status: Offline Points: 200 |
Posted: June-23-2022 at 2:47pm |
I'm putting the ole 78 back together and as Murphy's would have it, I'm unable to find the one picture i need to put the hoses and rwp back on correctly.
If you have a front looking picture or even a diagram of the water path, it'd be a big help. Thank you! |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
Here are a couple of pictures
For your Reverse Rotation engine the screw head on the pump a little below the red arrow should be facing outboard like in the second picture |
NeilMcG
Thank you!
NeilMcG
What size hose is needed for the lower t-stat housing to the RWP?
I think you mean from the lower t stat housing to the circulating pump
It's 1 3/4 inch ID and a foot will take care of you. A short piece about 2 1/2 inches or so between the circulating pump and the j tube and a longer piece from the j tube to the lower housing. The longer piece is around 6 inches long
NeilMcG
Oh yeah...that's indeed what I meant.
Thank you!! |
