Distributor options for RH |
NeilMcG
Senior Member Joined: September-20-2021 Location: Pittsburgh, PA Status: Offline Points: 228 |
Posted: August-23-2022 at 10:47pm |
Well, after all the top end work, the engine is getting pulled as I discovered only half of the problem was fixed with the 78 nautique 351.
Getting bored, honed... the works,. Thought this is a good time to upgrade distributors, but finding ones specifically labeled as rev rotation is difficult and unbelievably expensive. Am I correct in that you can just replace the gear to convert a std rotation to RH? |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
Performance Distributors. They have D.U.I. (Davis Unified Ignition). The part number for a reverse-rotation distributor for a SBF 351 is M35820RRRD (the last 2 letters "RD" means a red distributor cap). This is an HEI style distributor, so no external coil is needed. Not cheap.
https://performancedistributors.com/product/marine-dui-distributors/ JQ |
gun-driver
What's in it now, points or a electronic conversion?
NeilMcG
It's an old Prestolite with a e-kit from pertronix that is no longer in production. |
gun-driver
If it works I wouldn't mess with it, if it doesn't, I would get a new E-kit for it.
I would not spend the money on a HEI for it that's for sure.
