thermostat |
BaccoBouncer
Senior Member Joined: April-25-2016 Location: Essex MA Status: Offline Points: 272 |
Posted: June-28-2023 at 8:15pm |
ok thanks
'97 21' Sport Nautique
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10719 |
I still say that's the way it should be. A little bypass flow while the engine is warming up
Since you're thinking about a new thermostat housing, I'd at least try using what you have now. You might like it |
BaccoBouncer
SKIDIM has this. https://skidim.com/housing-t-stat-indmar-gm.html
BaccoBouncer
With the thermostat is I can see past the edge of it to the bottom of the manifold.
BaccoBouncer
This is what it looks like with the adapter in
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 166 |
Sorry for the miss information. Thanks Keno! |
That's how it's built It's one of the flow paths through the housing. The retaining adapter (part #6 in the manual) goes in with it's opening lined up with that opening. The adapter only fits one way, there's a ridge that lines up with the groove at about the 1 o'clock position in your picture. As far as the thermostat, it won't hurt to try the 160, you may like it . If it runs a little warmer than you're comfortable with, get a 143. |
BaccoBouncer
If so, is this an appropriate replacement: Mercruiser 860256A4
https://marineenginedepot.com/thermostat-housing-43l-57l-raw-water-cooling-system
BaccoBouncer
Is the manifold sealing surface to the thermostat broken or is this section supposed to be missing?
BaccoBouncer
Oh Wow, That's perfect. THANKS!
I see this thermostat shows as a 160 degree when I look it up online (not 143). Does this matter or is 143 required?
If you click on the link below and go to page C4-1 and C4-2 you'll find your thermostat housing for 97 and later PCM engines
link It takes an automotive style thermostat like yours. It also shows the earlier one that took the big, tall, expensive one. The exploded view shows how it goes together Pointy side towards the sky It's not like Paul's
pjsmoreno
The thermostat silver metal goes up into the thermostat housing and the dark area where the spring is goes into the intake manifold, Paul
pjsmoreno
I know you said your engine is a 350 Chevy. That thermostat
housing is the same as my 454 Chevy is but the thermostat itself is way different
then your setup is. Are you having problems with the engine not warming up to
correct temperature? The gasket is the standard Felpro thermostat gasket for a
small block Chevy. there should be a lip around the housing for the thermostat
to fit into and then the gasket goes on.
The thermostat I used on my engine is much larger and it fits
up inside the thermostat housing. And I hate to say it but the thermostat from
SkiDim is $111.50, Item #: RP026003. When the engine reaches operating temperature, the thermostat
opens up into the housing to let the warm water out into the exhaust risers. I
believe that’s how it works. |
BaccoBouncer
I have a '97 Sport Nautique with the Chevy 350 PCM engine. I need to replace the thermostat but I think what is in there is not correct. My questions are. What gasket is needed internally, o-ring, cork, etc? Does this gasket go in first and then the thermostat and then the plastic collar/spacer. What gasket do I need for the manifold attachment to the block? Which side of the thermostat should I see after I assemble it into the manifold? Thanks
