  New Posts New Posts RSS Feed - 79 BFN with 454 does in gear
barefootdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barefootdan Quote  Post ReplyReply Direct Link To This Post Topic: 79 BFN with 454 does in gear
    Posted: July-06-2023 at 10:05pm
My 79BFN will start and run fine then when I stop and put it back into gear the boat does. I need to turn the idle screw up to 1500+ rpm to get back into gear to run but it slams into gear and runs like 8 mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2023 at 8:05pm
Below is the quote from your other post
My 79 BFN runs fine off the water but sa soon as I put it in gear it wants to die I put a new carb and still same
I can't quite figure out if you start it cold and drive it around for a while, then stop and then you have the problem when you put it back in gear (quote 1) or if you start it cold and put it in gear, it quits (quote 2)
What do you have for an ignition system on the engine?
PS..........you can edit the title to say dies in gear Wink
