  New Posts New Posts RSS Feed - Which fuel sending unit for a 1990 SN?
uncle-buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uncle-buck Quote  Post ReplyReply Direct Link To This Post Topic: Which fuel sending unit for a 1990 SN?
    Posted: August-19-2023 at 7:24pm
After almost 34 years, the fuel sending unit in my '90 SN needs to be replaced.
The tank itself is 11" deep, so I think a 10" sending unit is recommended.
Which type and brand do you guys prefer?
Have seen some that have a float arm that swivels - and others that have a straight vertical post with a float around it.
The top of the existing unit has three wires that connect to it.
Will the fuel tank need to be removed?
Thanks for any suggestions and advice.
1990 Ski Nautique (original owner)
PCM 351W with D.U.I.
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2023 at 9:30pm
Here are a couple of threads in the links with some info.
These days WEMA is spelled KUS Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2023 at 12:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote uncle-buck Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2023 at 7:56am
Many thanks, guys.
Will probably go with a reed style sending unit and put it on the list of winter projects.
Getting that tank out is going to be a challenge...
1980SN2001 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1980SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2023 at 10:19am
Shameless plug for Ron at skiboatpartsonline.com
They have the reed switch sending units which is where I got mine and Ron is a very nice and helpful person.
https://skiboatpartsonline.com/index.php?route=product/search&search=reed
1980 SN Project
