Transmission leak |
gmoser
Newbie Joined: April-26-2018 Location: Hickory nc Status: Offline Points: 6 |
Posted: September-03-2023 at 12:40pm |
Can you use auto pro fluorescent dye in a 1990 ski nautique transmission? Dexron 3
Not sure if I overfilled or It has a leak! If so how much? |
1990 Ski Nautique
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10652 |
Since you have some pretty bright red ATF in there now, I'm not sure why you want to add the dye.
If you can't find anything obvious and you're losing fluid, there's a good chance it's the front seal on the pump, which leaks into the bellhousing which then leaks into the bilge. You should be able to find it without using the dye and a UV light.
