  New Posts New Posts RSS Feed - Won't Turn Over w/plugs
NeilMcG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Topic: Won't Turn Over w/plugs
    Posted: July-30-2024 at 6:54pm
Newly rebuilt 351 PCM. Rh Rot.
Has not been started yet.
Turns over with the plugs out, but once the plugs go in, it won't turn.
Brand new battery, brand new starter. All wires are new as well.
Any thoughts on what could be causing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2024 at 7:32pm
Are your plugs correct for your new engine?   Any chance the plug is hitting the piston?
Most new engines will turn over with drag but can be turned with a wrench.  If your engine is in the boat it would have to be turned using the harmonic balancer bolts on the front of the crankshaft.  Most engines will turn over with about 18-22 ft pounds pressure if using a torque wrench.   This is assuming your issue is mechanical.  If a piston is hitting the spark plug the plug gap will be bent closed or you will see some contact damage to the plugs.
Maybe you just have a bad connection in your wires, with no plugs in it turns over because there is much less load / no compression, install the plugs and it is demanding an amp load that bad wires, connections or battery can't deliver.
The other possibility I am thinking of, maybe you have hydro lock.  Water or fuel is entering the chamber and when the piston comes up it hydro locks.  Could be coolant getting past the head gasket or gasoline flooding from the carburetor.   With plugs out that fluid. would just drain out a spark plug hole, plugs in it locks up?
Warning, if this is a flat tappet/lifter engine do not keep cranking the starter motor with no start.  Cranking alone if extensive can make a new cam go flat.  The engine must start and run at 2,000 RPM for 20 minutes right away to break in a cam.   IF you are in doubt Pay someone to come help before the cam is wrecked it will save you a lot of money and time.  If it has a roller lifter cam in it you can ignore this statement.
Good Luck, hope it is a simple fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2024 at 8:36pm
I'm using Autolite 24's and since it doesn't even turn there's no concern about contact.
It does take a great deal of force to turn once the plugs are in with a breaker bar, but it does turn. I've heard mention about the distributor possibility being the problem if it was installed incorrectly or if there's too much advance, but I can't see how that could have any effect in its ability to just turn.
All the wiring is new.
I'm completely stumped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2024 at 11:02pm
There is no way to diagnose over the internet.  We can only give you ideas and hope we find the cause.
I do not know your experience level so no idea if we are speaking and understanding.
If it turns over with no plugs but will not turn with plugs your distributor is not causing a mechanical lock up.
Timing is important.   If the timing is wrong it is possible to have fuel air and compression trying to explode in the cylinders well before the piston hits Top Dead Center and it can try to blow the piston back down, if they are all way off you might have lock up but it would turn fine by hand.   Or plugs installed remove the coil wire, that takes timing out of the equation.  If it still turns hard there is a mechanical issue, if it turns freely, while fighting compression as each cylinder hits TDC your issue is timing, spark plug fire order or both.
A new engine can be turned into junk quickly by a poor start up procedure.   It needs to be timed correctly, have fuel available and you want it to start on the first or second crank to properly break in the cam.  Not something to guess with or it will cost lots to fix it.
I really hope you find some silly easy thing and it fires right up.
Maybe go back to the engine builder for help/advice?   If not most Shops with an engine Dyno have operators that know how to check tune and can do it quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2024 at 9:39am
I would also prime the entire oil system using a hex drive on the oil pump by removing the distributor.
Example:  ARP oil pump primer 150-8801.
Use a drill to the run the oil pump prior to starting.  Keeps everything nice and lubed up to avoid a dry start.  Do a search on YouTube and you will find lots of good videos showing you how to do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2024 at 10:04am
Sounds like that brand new battery is low on charge. What’s the voltage read at the terminals? Did you charge it after purchase?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2024 at 10:12am
I very recently had the exact same issue on a Ford 312. In the end, it was a matter of valve adjustment.
I had to carefully adjust them with the intake open-do exhaust. Exhaust closing-do intake method.
(there were several other challenges probably not applicable here...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2024 at 4:17pm
A new battery will read around 12.8 Volts, (12.6 is considered fully charged)   If you are down to 12.0 Volts the battery is only at maybe 35% charge.  I don't have the chart memorized but your power level drops off fast as the battery gets closer to 12V, as Tim advised, make sure the battery is at full charge.
All Battery manufacturers advise you to fully charge the brand new battery before use.   Sometimes the battery will sit on a shelf before it sells for many months.  They discharge slowly while sitting on the shelf.   Many batteries today are built outside this country, they may be on a boat for Weeks before arriving in the USA and weeks more before you buy it at your local source.
If that is your only problem you are in great shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2024 at 7:01pm
Mr McG or Neil (or Bellagio Boy)
Not really knowing what you've used for a timing set, there's a chance that the backside of your cam gear may be rubbing on the camshaft retainer plate/bolts. There were variations over the years with different types of chain and gear sets. (Roller chain vs silent chain)
It can happen and that would produce lots of extra drag when turning things over by hand or with the starter.
A check of my memory banks seems to tell me that I had this problem once upon a time, but got lucky and found it before buttoning up the timing cover.
It's kinda a sneaky gotcha when tightening things up Wink
Not really what you want to hear, but I'd probably take the timing cover off, then take the chain and gears off to check for "self machining" rub marks on the backside of the cam gear.
It's worth a look if everything else has you stumped
Also I checked how much force it took to rotate a good running fully assembled 351W engine by hand. It was in the boat, plugs installed and it took about 50 ft lbs to make it rotate.
I checked another engine too with the same results
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2024 at 2:29am
Ken your engine is tested plugs in, the lower torque of 18-22 is plugs out.  Racers at the track used to do that check between events just to make sure the bearings were not starting to fail.  A quick test.  If they noticed the torque number increasing they were done for the day.  Plugs in it is hard to say how much drag since it increases with every compression event.
DenDen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenDen Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2024 at 4:41am
Try it with one plug-in and see what happens.
If it were a Chevy with right hand turn, there would be no timing chain. I’m not familiar with the Ford, but I would assume it would be the same thing. Maybe you have the wrong timing gears on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2024 at 6:36am
Not the best assumption............ Ford still uses a timing chain on a RR 351w  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2024 at 6:40am
Umm......I think I knew that Wink
I was giving him an idea what it takes to get it turning with the plugs in since he mentioned that it took "a great deal of force"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2024 at 11:06am
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2024 at 5:31pm
What if...the new, out-of-the box cam is incorrect? Got it from Summit and clearly stated it was for rh 18456273. Could that cause a problem such as this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenDen Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2024 at 8:25am
Take the spark plugs out and the valve covers off. Manually turn it through the firing order and watch what the rocket arms do. Starting with number one, follow the intake,compression, power, and exhaust stroke of the valves all the way through eight cylinder cycle and make sure it is correct, this is very simple to do and will tell you if the camshaft is correct. I just put together a right hand 350 Chevy and it can be quite confusing for everyone involved.
If you do not know when your valves should open and close on each of the strokes, I am sure you can find someone to help you.
You could also take the distributor cap off and watch to make sure that at the end of each compression stroke the rotor is very closely pointed at each location it should be in the firing order.
This is very basic and easy to check.
