  New Posts New Posts RSS Feed - 98 SN Fuel Control Cell filter change
davidaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidaha Quote  Post ReplyReply Direct Link To This Post Topic: 98 SN Fuel Control Cell filter change
    Posted: October-24-2024 at 10:10pm
Trying to change the fuel control cell filter on my new to me 98 SN.   Have the replacement part in hand.    Did the eletcrical disconnect and drained the canister.    Can't get the canister to rotate (rotating left).    Tried used 2 different types of oil filter removal wrenches.   One that is a metal strap and one that is more like a large pair of pliers.   Have applied enough force that the bracket holding the canister to the engine started to flex.   Don't want to damage the canister.
Any suggestions on getting it to break free or a type removal tool to use?
The non injected 92 that before this had a tight fuel filter, but I was alway able to get it to rotate.
92 Ski Nautique
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2024 at 2:14am
Disconnect the whole fcc and put it in a vice. You can then use a nail bar between the bolts to spin the cap. They sure can be tight.
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2024 at 7:21am
It sounds like you're turning it the right way, but I'd probably read the link below and watch the video in the link just to make sure you're rotating it the right way Wink
Then go for a big pipe wrench or a big chain wrench or like 2001SAN said, take it out of the boat for better working conditions
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidaha Quote  Post ReplyReply Direct Link To This Post Posted: Today at 9:08am
Thanks.    Found an 18" strap wrench locally.   And eventually got it loose.
92 Ski Nautique
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: Today at 10:30am
I use a big-ass pipe wrench — 24” aluminum from HF.  I wrap duct tape around the canister in an attempt to minimize the tooth marks from the pipe wrench. Works every time.
