  New Posts New Posts RSS Feed - Electrical Work 2003 SANTE
Rob-Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rob-Man Quote  Post ReplyReply Direct Link To This Post Topic: Electrical Work 2003 SANTE
    Posted: October-28-2024 at 2:33pm
The auto bulge pump is not working, I live in St. Louis.  Does anyone out there know anyone close who can work on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2024 at 8:11am
Have you checked anything obvious like voltage?  Does it work in manual?  Is something lodged under the float switch?
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2024 at 9:55am
  there is not a float switch under those bilge pumps unless someone has replaced it. Nautique utilizes an automatic pump that cycles every few mins, if there is not any load on the pump it shuts right off. Check voltage on the brown wire. if you have 12 volts there and the pump is not cycling it will need replaced. here is the link for the replacement. https://nautiqueparts.com/bilge-pump-automatic-most-models/
