  New Posts New Posts RSS Feed - tune up questions for a 94
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: tune up questions for a 94
    Posted: December-21-2006 at 6:52pm
have a 94 with the 351 5.8 h.o. pro boss carbed w/ the pro-tec system.......what all do i need to order to give this baby a tune up..........plugs wires and............????
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2006 at 11:25am
Cap and Rotor.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2006 at 11:38am
Originally posted by Rick Rick wrote:
Cap and Rotor.
Not applicable on a Protec boat, are they?
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2006 at 3:57pm
Cap and Rotor.
Tim, I believe you are correct, has the trigger wheel.
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2006 at 9:15pm
Don't forget to replace your fuel filter/s.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2006 at 1:28am
getting ready to do plugs and wires on mine too...clean up the carb and spark arrestor...change all fuel filters as has already been mentioned.
Mullet Free since 93
95 Sport
1978 Ski Nautique
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-26-2006 at 1:33pm
...so thats it then?
tnplicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnplicky Quote  Post ReplyReply Direct Link To This Post Posted: December-26-2006 at 5:48pm
Sorry... I can't help with your tune-up questions - I'm learning the ropes myself, but I wondered if you have experienced the same occa$$ional start-up problem I have. It sounds as if you have the same engine set-up in your '94 as I have in my '95.
See "Startng Problem - 1995 Ski Natique" under Boat Maintenance
SkiLuNautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiLuNautique Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2006 at 1:01am
Kind of like when you went to a party in high school, go away now, see ya, come back when you can't stay so long!
Hamlin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamlin Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2006 at 10:17am
Change oil and filter
Check plugs; Replace if pitted or burned
Check wires; Replace if stiff or damaged ends
Clean spark arrestor
Check belt tension
Check fuel water separator
Replace fuel filter
Check timing
Check idle speed
Check trans oil
Check prop shaft packing
Check battery water level
Check all hose clamps
Check all electrical connections
Check and clean the water strainer
Grease trailer wheel bearings
Check trailer brake fluid
And most importantly, Wax the hull; Nothing runs better than a shiny boat.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2006 at 6:38pm
no i dont not have the same problems as you.sorry i cant help ya out.....skilu, um ya lost me, but o.k.........hamlin thanks, how do you check your timimg?.i a$$ume you have to buy a timing gun/light?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2006 at 7:13pm
Youre correct- you would need a gun to check your timing. Might not be worthwhile unless you suspect you have a timing problem though- I dont believe you can adjust the base timing with the Protec.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2006 at 9:51pm
for further knowledge, what or how would a boat react if the timing is off?.......what kind of symptons would the boat have?
