tune up questions for a 94 |
Guests
Guest |
Posted: December-21-2006 at 6:52pm |
have a 94 with the 351 5.8 h.o. pro boss carbed w/ the pro-tec system.......what all do i need to order to give this baby a tune up..........plugs wires and............????
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Cap and Rotor.
Not applicable on a Protec boat, are they? |
quinner
Tim, I believe you are correct, has the trigger wheel. |
nuttyskier2002
Don't forget to replace your fuel filter/s.
The Dude
getting ready to do plugs and wires on mine too...clean up the carb and spark arrestor...change all fuel filters as has already been mentioned.
Mullet Free since 93
95 Sport |
Guests
Guest |
...so thats it then?
tnplicky
Senior Member Joined: December-22-2006 Location: C'trl Illinois Status: Offline Points: 333 |
Sorry... I can't help with your tune-up questions - I'm learning the ropes myself, but I wondered if you have experienced the same occa$$ional start-up problem I have. It sounds as if you have the same engine set-up in your '94 as I have in my '95.
See "Startng Problem - 1995 Ski Natique" under Boat Maintenance |
SkiLuNautique
Newbie Joined: September-29-2006 Location: On top Da Water Status: Offline Points: 12 |
Kind of like when you went to a party in high school, go away now, see ya, come back when you can't stay so long! |
Hamlin
Groupie Joined: November-19-2006 Location: United States Status: Offline Points: 57 |
Change oil and filter
Check plugs; Replace if pitted or burned Check wires; Replace if stiff or damaged ends Clean spark arrestor Check belt tension Check fuel water separator Replace fuel filter Check timing Check idle speed Check trans oil Check prop shaft packing Check battery water level Check all hose clamps Check all electrical connections Check and clean the water strainer Grease trailer wheel bearings Check trailer brake fluid And most importantly, Wax the hull; Nothing runs better than a shiny boat. |
Guests
Guest |
no i dont not have the same problems as you.sorry i cant help ya out.....skilu, um ya lost me, but o.k.........hamlin thanks, how do you check your timimg?.i a$$ume you have to buy a timing gun/light?
Youre correct- you would need a gun to check your timing. Might not be worthwhile unless you suspect you have a timing problem though- I dont believe you can adjust the base timing with the Protec. |
Guests
Guest |
for further knowledge, what or how would a boat react if the timing is off?.......what kind of symptons would the boat have?
