  New Posts New Posts RSS Feed - Have you worked your...
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Topic: Have you worked your...
    Posted: January-25-2007 at 10:22pm
OK, middle of winter, have you worked the steering back and fourth on your boat lately? I did mine last weekend. Just to make sure nothing freezes or seizes.
Tim D
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2007 at 10:32pm
I think quinner has been workin' something back and forth so it don't get stuck.
john
"Loud pipes save lives"
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 9:15am
A true Olympian practices everyday
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 10:10am
Who would have thought you gotta crank it back and forth to prevent it from getting too stiff!!
Seriously though, I have spun mine every couple weeks since we tucked it away last fall.
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 10:57am
Just went out and cranked it back and forth a couple times.
which leads me to this question:
I seem to have a little play in the steering. I can move the wheel an inch or two before it resists. Steering also seems a little stiff. I know the previous owner replaced the steering cable about three or four years ago after it froze up. I tightened the rack an pinion unit under the dash where it is mounted but their is still some play. Do you think the cable needs to be replaced again?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 11:33am
It is my understanding that a cable going bad only causes stiffness. Any "play" would be coming from gears/linkages on the ends.
Is this true?
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 11:43am
not sure Kevin, when mine snaped there was a little play in it before it went, but then again we where doing 180's at the time too and it was a pain getting back across the lake using the paddle as a rutter.
with the R&P type I would think there would be a little backla$$ in the gears that would create a little slop.
todicus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 12:22pm
On my 95, I have about 1 inch or so of play before it engages the cable........ It bothered me as well, so I tightened everything up that I could under the dash. The slop that I was getting is because of the tilt steering knuckle which has a little play in it, with a small anount in the R&P . Not much I could do about it......... I've gotten use to it now.
Living outside the wake
95GT-40SNOB
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 12:38pm
Randy ,Hollywood,
the slack that exist in a rack and pinion is there from day one,for this reason i always replace with a rotary style. Takes up less room,and is generaly slack free.
They come in two styles,No- Feedback and convetional.The N/F has a tad bit of slop,benefit being the wheel gets no feed back from the rudder.
If you have slack in any parts,time to upgrade.Steering parts,cables and helm a$$y. are cheap compared to crashes that are caused by the failure of one of those parts..................boat dr
