  New Posts New Posts RSS Feed - Valve Adjustment 210HP Chrysler
barr68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barr68 Quote  Post ReplyReply Direct Link To This Post Topic: Valve Adjustment 210HP Chrysler
    Posted: March-05-2007 at 7:31am
After reveiwing all of the information I could find on the 1968 Lm-318 Chryslers, I have come to the conclusion that the valve train on the 1968 210hp version(solid lifters,adjustable rockers) must have carried over from the 1967 M-318 polyhead. The 1968 LM-318 235hpversion incorporated hydralic lifters and non-adjustable rockers. One of my manuals is for a LM318B 225HP version(hyd. lifters,non-adj. rockers), but the manual is not dated. I assume this must be a 1969-70 version of the 1968 235HP model. FYI. Someone correct me if I am wrong . Thanks ,Jim B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barr68 Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 7:24am
Thanks for all the responses,the engine is indeed a LM318,210HP. From what I have read in the manual that I have ,the 235HP version of the LM318 had hydraulic lifter and required no valve adjustment . I do not have a manual that specifically states wether or not the 210HP version (a$$ume solid lifters because of the adjustable valves /rocker arms)should be at operating temperature or cold for valve adjustment. One other question, I run my boat in fresh water only, should I replace the stock 140 degree thermostat with a 160?Thanks for the help! Jim B.
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 11:12pm
The '68 would be the LM engine like Gary said. They made the switch in cars in 67 but some early 67 CC's still have Polys. Both are solid lift up until '69 or 70 I believe, as I know we had a '68 which was solid and a '70 that is Hyd.
ReidP
1973 Mustang
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 8:16pm
The manual calls for adjustment every 50 hours, although it does not say, I'll a$$ume solid lifters. All of this info is for the M series (polyhead) Motors, the later LM series may be completely different. The odds are that a '68 has an LM motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 6:20pm
hyd or solid lifters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 6:17pm
The manual says the intakes are .012 and the exhausts are .022 tappet clearance with the engine at normal operating temperature.
Page 32 of the " Chrysler Marine V-8 Engines" manual in the reference section of this web site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 4:46pm
doesn't really matter. if you just installed them then you really don't want to wait for it to warm up before they are adjusted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barr68 Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 1:25pm
I have a 1968 210 HP Chrysler in my Barracuda. Should the engine be at operating temp to adjust the valves or should they be adjusted cold. Thanks ,Jim B.
