Bad Vibes |
skibama
Newbie Joined: November-25-2006 Location: United States Status: Offline Points: 11 |
Posted: March-18-2007 at 9:42am |
I have an '89 BFN.It has vibration that begins at about 40 to 45 mph and goes beyond.I have noticed that on inspection the prop has a very small amount of slack movement.Could it be that it was not pressed on far enough or is there supposed to be a spacer inbetween the prop and nut to absorb this.
Guests
Guest |
i dont think your prop should have any play..i know on my 94 it has zero
skibama
It has a very small amount of play.When I originally found it I took off nut and washer but the prop was tight to and fro but had that slight side to side wiggle which I guess after saying that could be a sign of a worn key.
The key may be positioned wrong not allowing the prop to seat properly on the taper. It should tight. The only other problem that may cause this is a warn taper on the prop and or shaft. This is only caused by the prop being loose for a long time. Take it off and see how it fits without the key. The key is there not to tighten the prop to the shaft but for the tranmission of torque to the prop. In therory the key isn't even required with a good fitting taper.
skibama
I really do appreciate the info fella's I'll pull the prop tommorow and I'm sure I'll find the problem
87BFN owner
any pics of your boat? What did you find when you removed the key?
skibama
Haven't had time yet,but I'll let you know when I do.I'm having trouble uploading pics so when I figure this out I'll post them.The image upload is telling me the image is to big
Randy_in_Ohio
Skibama,
There is a 32kb size limit using the upload feature on this site. pretty small. try using photobucket.com or some other hosting site. look at my post How to post pics using Photobucket |
