Updated Alternator |
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Posted: July-09-2004 at 1:06pm |
My regulator went on my 1979 PCM Ford 302. My local guy recommend updating the alternator with a delco marine alternator that has an internal regulator and also puts out more amps.
Beyond being an updated solution, it will cost less and be ready Monday vs. 3 weeks from now (regulators are hard to come by I guess). Does anyone see any issues? Thanks, Keith |
Farkum
Groupie Joined: June-10-2004 Location: United States Status: Offline Points: 41 |
What is that costing you and how many amps? I may be interested in doing the same thing.
1979 Ski Nautique
Will post pictures soon |
Keith
It's going to run about $85 for a rebuilt alternator that uses an identical casing. I don't know this stuff all that well but I think he told me it will be about 75 amps up from about 30 amps I guess.
-Keith |
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
new mando 55 amp for 120 , puts out way more than stock , boat even runs better. cheap parts at amarket.com 71c rebuild kit for 75 , pertronix point conversion 69 , lots of stuff.
danman
Groupie Joined: February-04-2004 Location: United States Status: Offline Points: 56 |
Keith-
I had my stock 32 amp alternator rebuilt at a alternator/starter shop for $40.00 and you can by voltage regulators all day long at any local parts store. I just recently bought one from auto zone that is solid state (meaning there is no mechanical coil/relay towers - it is a printed cirucit board) for $10.00..... |
64 Skier
My engine has an Interceptor Starter with solenoid on top. I went to a "single wire" marine alternator with internal voltage regulator and got rid of the external voltage regulator and solenoid.
Very clean wiring, easy to work around and it's worked well all summer. |
jdreiser
Newbie Joined: June-07-2004 Location: United States Status: Offline Points: 34 |
I replaced the 32 amp alternator with the 51 amp alternator w/ internal regulator sold through DIM. I was adding a stereo and wanted the extra juice. Changed to a voltmeter at the same time. Very easy change over. Vince answered all of my questions.
