  New Posts New Posts RSS Feed - 1979 Barefoot Nautique Propeller
Kevin's '79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin's '79 Quote  Post ReplyReply Direct Link To This Post Topic: 1979 Barefoot Nautique Propeller
    Posted: March-26-2007 at 2:31pm
Can someone tell me what prop came on a '79 Barefoot Nautique with a 330 hp 454?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 7:47pm
Im going to dig up this old post and speculate that the '79 BFN came stock with a 13x15 3-blade Federal. I know later BFN's came stock with a 14x14, but they have a bit of the keel cut down aft of the strut- the '79 did not. Im curious what year the change was made to the hull.
Anyone out there got better info?
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 8:47pm
My 81 BFN has a blocked off keel. I can't speak to the 80BFN.
bj
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2009 at 8:25pm
I confirmed with Woody last week that the '79-80 BFN got the 13x15 3-blade Federal from the factory. 81+ got the notched keel which allowed them to fit the 14x14.
The Acme 612 (12.5x15.25 3-blade) is a suitable replacement for the 13x15, as would be the 470, I think.
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 12:08am
What has been the best prop on the BFN (86 era)? Mine is toast after GL & I am looking to replace it with something a little better on top end & a little higher RPM. With the 4 blade that was on it, I was only turning 4000 RPM's @ about 46.8 mph.
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 12:44pm
Greg, I think Jim Bragg has been happy with his 13x14 Acme (1458???). That prop was made for the RH big blocks. Id like to try one on mine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2009 at 3:00pm
Figured Id share a few pictures I was able to find that show the notched keep in the 81+ BFN's. This allows them to run the larger diameter (14") prop, while the 79-80 BFN's (without the notch) came with the 13x15.
(Thanks Rookie and HW/Feelgood)
In other news, the 1458 arrive this week. We'll be slapping it on this weekend to see how it does- I have high hopes! In talking with Bill Weeks, theres also a 1598 that is supposed to work great on the stock 330hp big blocks. It's a 13x14 3-blade like the 1458, but has less cup (.080 vs. .135) so it turns a few more RPM's. Id like to try that too, but Acme was out of stock!
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2009 at 3:10pm
Does the horizonal stabilizing fin keep her for porpoising? (o:
If the only tool you have is a hammer,everything starts to look like a nail.
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2009 at 4:12pm
What happened there, now that you mention it, with a little experimental engineering you could make that thing work just like the fins on a slalom ski or better yet like the fins on the Cup sailboats...
