  New Posts New Posts RSS Feed - Oil Weight for 302 PCM??
acpskitique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acpskitique Quote  Post ReplyReply Direct Link To This Post Topic: Oil Weight for 302 PCM??
    Posted: April-12-2007 at 12:38am
I need to know the what weight oil I should use for my '76 302? The engine is probably original. I've searched a lot of threads but still no real answer. I really want to know from someone who knows for sure from PCM what they currently recommend for the older v-8's. I know that I'm sticking with Valvoline, but I'm kind of confused whether I should use 10W-30 or 10W-40? I live in Florida. What are the opinions about synthetic blends with an older engine?? Thanks.
'76 Ski Tique 302PCM
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 12:55am
Adam; I am in Florida too as you know and I use 20W-50. I also run that weight in Tennessee when I am skiing alot. With the warm water temps and the warm air I like a little heavier oil. But there are lots of guys on here that know more than me.
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 7:38am
Stick with conventional, especially on an older flat tappet motor. Valvoline and Rotella-T are the brands to go with. PCM's official recommendation is straight 40w, but you should be fine with 10w40, 15w40 or 20w50. JBear's recommendation is a good one- Id stick with one of the heavier weights since youre in FLA.
Also dont forget a quality filter (Motorcraft, Wix/NAPA, Purolator).
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 9:49pm
Thanks for the "props" Tim. I take that as a compliment as you know way more about these boats than I do.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote acpskitique Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2007 at 12:04am
Ok, and I also need to know the capacity of the oil?? I would think it was a total of 5 quarts with a filter change...but I'm not sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2007 at 12:30am
You got it. Just make sure you use the good stuff.
john
