302 / Proper Oil Pan |
Old Man Barlow
Newbie Joined: April-01-2005 Location: United States Status: Offline Points: 9 |
Posted: April-20-2007 at 4:11pm |
Our 302 rebuild has original (Ford Mustang) sump-forward oil pan. We need the proper pan (rear sump, perhaps?) and pickup for '65 Barracuda. Any recommendations for a supplier?
Yes, we are aware of rotation issues and have that handled. Thanks in advance. |
Old Man Barlow
'65 Barracuda |
Tim D
mine looks like this.
Tim D
Old Man Barlow
Thanks, Tim D. We used your picture to hone in on a 70's era Bronco oil pan for 302 Ford. Seems to be 'zactly the same as yours.
Restoration commencing...... |
Old Man Barlow
'65 Barracuda |
Jim_In_Houston
Tim, how does your dipstick tube affix to the pan? Where'd you get that oil drain hose? Does the oil drain hose work for you?
JoeinNY
Grand Poobah Joined: October-19-2005 Location: United States Status: Offline Points: 5695 |
Mine looks like Tim's and the tube just pushes in with a little bit of force. It actually needs to be pulled out before you move the engine since it goes through a hole in the engine mount.
-Joe. |
Tim D
The dip stick tube goes in the hole plate you see mounted to the oil pan (small amount of rtv). The drain hose is home made. Just a couple of brass pieces. It works fine, just have to postion the hose beside the bilge pump so it lays down hill through the drain plug hole. I keep the end of it attached to the hose going up to the rwp.
Tim D
