i need help with 78 ski tique |
watkins27
Newbie Joined: April-21-2007 Location: United States Status: Offline Points: 25 |
Posted: April-21-2007 at 6:12pm |
ok here we go.i bought this boat as is, the problem is sometimes it has spark and sometimes it don't.whoever had it before me changed it to elec.from point distributor.i have check everyting else this is the last thing to replace i think.i just need some advice,is there a kit to rebuild elec. or should i put a point distributor back in it. could it be someting else .thank you for any advice.
Tim D
First check the distributor cap for cracks. Then take a circuit tester ( one of those screw drivers with a light inside the handle) put it on the negative side of the coil and ground it and crank the engine. If the light blinks, the distributor is breaking fire. If the light doesn't blink the module inside is dead, and probably has a little crack with a burnt place on it.
Tim D
79Tique
Senior Member Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
Do not go back to the point stuff. The electronic is a upgrade everyone likes.
Work to live, not live to work.
watkins27
thanks for the help it is blinking
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
My experience says ignintion switch
Munday |
rudderdad
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 44 |
Next thought is coil getting hot, and failing
rudderdad
