  New Posts New Posts RSS Feed - Mustang Seat Frames
Mustang Seat Frames
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Topic: Mustang Seat Frames
    Posted: May-04-2007 at 1:14am
We'll see how these work out. They are being fabbed out of 1/4" by 2" marine grade aluminum flat bar.
The pic is hard to see on the forum so I uploaded a PDF file to one of my websites and here is the link:
Boat Seat Frame for Old Mustangs
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2007 at 11:24pm
Looks good . So then what are you going to do ? Make ply wood frames for cushions and the screw them to the aluminum?
Pat
Pat
My 72 Skier
Rock River
Dixon,ILL.
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2007 at 9:56am
JIH,
IMHO those backs have no "section" and will bend if you lean back. The 1/4" is awfully weak in bending and without adding some depth or ribs perpendicular to what's drawn I think it's just too weak.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2007 at 10:56am
The plan is to take the frames to an upolsterer and tell him to make some seat cushions that fit. The cusions I have seen have plywood or some other material (some kind of synthetic) backing sewed into them. With female threaded inserts in the wood so I can bolt through the frames to hold the cusions on. I am not an upolsterer though so I think I will just leave that part to them - we'll see.
64 Skier, my thinking is that with some material in the cusion (plywood or synthetic) of about 1/2" thick, when the cusions are bolted to the frame there will be enough rigidity. Again, we'll see.
Also, the 1/4" risers on the back are doubled when welded, to 1/2" and again the back cusion will have a 1/2" backing plate inside it also. The 1/4" flat bar riser above the welded risers is only the top 8" of the riser. Plus there are two 1/4" thick cross braces welded across the back for a total of 1/2" of thickness leaving only 4" of 1/4" aluminum on the back cusion risers. From a practical point of view, the aluminum back cusion riser part of the frame is 1/2" thick not including the 1/2" of rigid material in the cusion.
If I get too much flex I can always weld on stiffners but I don't think I will need them. Again, we'll see.
Here is a pic I found somewhere. I am using the pic as a model. Thanks to who ever owns this boat and posted the pic.
