  New Posts New Posts RSS Feed - Temperature?
Temperature?
Clew In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clew In Quote  Post ReplyReply Direct Link To This Post Topic: Temperature?
    Posted: May-10-2007 at 9:26pm
Hey,
What is the correct running temperature? I have looked through the post and I see several temperatures. I have a 1982 Ski Nautique and my temperature fluctuates between 140-170. Is that normal?
Clew In
Clew In
Root View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Root Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2007 at 10:21pm
Clew that sounds OK but I'am not as educated as some of the other guys on this site.
all   I can tell you is I have a 86 and it runs around 140 at a idling pace and gets up to around 150-160 runing WOT or while pulling someone.
RootRacing
acpskitique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acpskitique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2007 at 12:26am
That temp sounds normal. Regular cars run anywhere from 180 to 200 degrees and that's with a closed cooling system.
'76 Ski Tique 302PCM
83_2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83_2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2007 at 2:59pm
I typically run between 150 and 170.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clew In Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2007 at 7:05pm
Hey,
I talked with Vince at DIM and he said the original thermostat was a 143 degree and now Ski Nautique is recomending using a 160 degreee. I ordered a 143 degree (the same as is in my motor now) thermostat. It has worked for 25 years why change.
He also said if you see your temp get over 200 shut the motor down asap.
Clew In
Clew In
bmiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmiller Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2007 at 2:38pm
My 1978 mustang with a 302 runs at 140 degrees and thats what DIM recommend for my boat.I ask the same question also.Hope it helps
