Anyone tried Mini-Craft Aerosol? |
ripster92
Senior Member Joined: April-13-2007 Location: United States Status: Offline Points: 254 |
Posted: May-25-2007 at 8:31am |
Pete,thanks for the info on the picture sizes. I'll remember to keep that in mind... Sometimes these get hard to hide at work
1992 SN Black w/ Yellow
Yeah that was me and my oversized picture. JBear, the garage is nice- that's my parents house. My dad is the one on the dock. |
Well, Now I screwed up with a double post and can't deleat it!
oops! I just took another look and it was Tim who did it with his side to side pictures! |
92, Hate to say it but you did it!! If you don't size your photos down to message board size, the photo will use up the width of the thread. The same will happen on multiple picture postings if they are posted side to side rather from top to bottom. If you use photobucket for downloading, you can resize to message board. |
jbear
Tim: Real nice garage!
Who is the guy on the dock in the barefoot suit? john |
ripster92
How do these posts get so wide???
ripster92
90 or 03... They're both clean lookin' boats TRBenj!
Only problem is my '90 is the one that needs the gelcoat work, not the '03! |
Steve, If I were to make a educated guess,I would say on a properly preped surface (not trying to cover up any bad spots) the can will do 15 sq. ft. I think you should sell Tim the can of the wrong color!! Then concentrate on your bad spots with the correct color.
ripster92
Thanks TRBenj, It's slowly getting there. I've replaced 2 bearings in a Matco DA. (Evidently they don't like being upside down all of the time. I think the condensation collects in the cap instead of exhausting out the side) I just got the reply from Mini Craft and of course it's wrong!!! I'll order the CORRECT one, but I'm debating using this one as sort of a primer coat to lighten the rub-through, then going over the whole bottom side white with the correct color. Does this sound like a stupid idea?
Ripster, did you hear back from Minicraft? Im curious if you got the right color. Boat looks good without the bottom paint, by the way!
Heres a pic where you can see the difference in color (white vs. new silver cloud). My deck has been restored to the original color (lots of wetsanding). Put it next to my dad's boat though, and it looks yellow. |
Steve, The aerosol doesn't have much pigment in it and is fairly low viscosity so it's sprayable from a can. It will take multiple coats to cover these spots plus extra to wet sand the orange peel. Count on the one can to handle the bad spots but that's about it. You will want to spray a fairly light coat then wait about 10 minutes for the solvent to flash off then spray again. Keep repeating this untill you can't see the black anymore and then spray some more for the sanding. Remember you have about 3 hours of pot life in the can. If you get a run or a sag, don't worry because after it's cured it can be wet sanded out. A word of caution: My first time using the stuff, I ended up having to order more! The first time you do anything is the "learning curve"
ripster92
Here are some pics of the burn-through spots on the hull. Pete, can you give a guestimate on how much a can of this stuff will cover? That is, spraying a reasonably light coat over existing gel. I was wondering if there was enough there to do the entire white of both sides (below the black stripe).
ripster92
I can post some pics when I get home from work. I've emailed Mini Craft to find out the color. I should have done this in the first place... I didn't know that they would go off of the hull #.
Steve, Before you mix up the gel that you bought, I would do some checking on the color. On the boat is not a good place to see if it matches and once you inject the catalist into the can you have commited the can to only about 3 hours of use.
How about posting some pictures of these low spots in the gel that you want to repair. |
Not sure if the naming of the color changed in '92, but the color itself is very close to the 90-91. The lighting isnt very good, but our former '92 is on the left, my '90 is on the right. |
ripster92
I see that in 90-91 they offered white or cool gray. In 1992 they didn't offer a choice. I'm hoping (but probably wrong...) that this was when they switched to the first Silver Cloud. Mini-Craft had a Silver Cloud and a "new" Silver Cloud. We'll see I guess...
ripster92
Thanks for the heads-up. I looked on the 92 brochure in the reference section. Silvercloud was mentioned. Now that I look at it, they were refering to the upholstry. I hope I'm right??? If not, does anyone need a can of Silvercloud?
Rip, Did you give Mini-Craft the hull vin for them to look up the correct color? |
Are you sure silver cloud is the correct color for a '92? I believe my '90 is white. My dad's '03 is silver cloud, and when we put the boats next to each other his is significantly whiter and cooler in color. |
ripster92
Thanks Pete. Well it has been ordered... Silver Cloud. I was figuring that it was a little expensive for a couple spots, but it beats ruining a gun and forking out for a pint of gelcoat. Besides, I'm sure the pump will get used again. Other people, other boats, Etc.
Steve |
Steve, Yes I have used it with very good results. It is pricey when you have to buy the pump for the catalyist but for small jobs I'd say you're better off than setting up the gun to spray. Do not expect it to spray like normal spray paint. It is true catalyzed gel and sprays like it. It will have tons of orange peel that will need to be hard block wet sanded and then buffed. Are you thinking of doing this on the 92 SN? Mini-craft should have the color mix for a 92. I know older boats they don't. The color will be damn close but not exact due to the virgin color of the get changing over 15 years. (it can be blended in to the surounding gel). If you go this route, I'd be happy to give you a few pointers.
ripster92
As I'm almost finishing up removing the bottom paint off of the hull that was put on by PO. I've noticed a couple spots where the black and yellow gelcoat upper colors are showing through the white of the hull. This must have been done when it was being roughed up to create bite for the new paint. Anyhow, I don't need much to cover these spots. There are a couple spots that are about 1x1". I was wondering if any of you have tried the mini-craft aerosol and any tips to applying it?
Steve |
