Prop Shaft and Rudder Needed |
lumiecraft
Senior Member Joined: June-06-2007 Location: United States Status: Offline Points: 104 |
Posted: June-06-2007 at 2:07pm |
I have a 1964 16' Correct Craft with the Stock Buick V6 or what is called the International Sabre. I am in need of a rudder and prop shaft strut.
Rudder is the Ski Style and has a short 6 1/2" shaft 1" diameter. The strut is 16 degrees with a 5 1/2" drop and the base is 5 3/4" long X 4 1/2" wide. It is a 1" shaft. I will also need a new/used stuffing box for the rudder. Rudder shaft is bent Stuffing box is busted Strut is bent. Alignment is fine. 530-749-2441 hm 530-301-7242 cell or email me or respond to this post. |
If you don't get it, be patient, you will.
lumiecraft
Check out the photos of the 64 Correct Craft.
One mistake to fix. It's not the international Sabre but the Universal Sabre V6 GM Buick engine. Photo Album |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1128 |
lumiecraft
Thanks, I have a message off to the guy about the parts. Looks alot like mine.
lumiecraft |
