Hesitation when throttle is nailed |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Posted: June-18-2007 at 9:14am |
Boat runs great, idle is great, excellration is great, WOT is great. Problem is when at idle, when I nail the throttle the engine bogs. If I start it cold and let is warm to normal temp, and nail it, it will just about stall. If I run it at WOT, and then stop and nail it, it will have just a very slight hesitation. Is this a timing or carb issue? Engine is a 310 Indmar GM with a Holley dual feed carb.
gigem75
Senior Member Joined: November-12-2005 Location: United States Status: Offline Points: 239 |
Does it just bog or spit back through the carburetor? might need to adjust the accelerator pump.
Riley
It just bogs. No backfire or spitting through the carb.
