getting the trailer and boat ready for a |
MaddMarxx
Posted: June-19-2007 at 1:00am |
I have have never pulled a boat 1400 miles, and I know others will pulling almost as far, I know I will need extra tires and bearings plus trailer locks, what are some of you guys going to do??
your going to need a jack for the trailer, and tools to redo the bearings if needed.4 way lug wrench is handy as well.
I would suggest repacking the bearings now and inspecting them in the process incase they need replaced or an oil seal is bad. Check the tread depth and look for weather cracking in the sidewalls of the tires. Take a spare but make sure they look like they'll make the trip. Double check the wiring front to back looking for loose connections or losely tied/secured wires to the trailer. Look at the shackel bolts and bushings make sure they look good and are not cracked or worn out. Check out the leaf springs/coil springs. Take care of the trailer now while you have a few weeks to get parts and replace them as needed. maks sure the safty chain is mounted securely, get a strap for the back of the boat so it's not hopping around on the trailer. Make sure your fenders aren't bent and rubbing the tires, don't over load the boat so that the fenders rub the tires. Check the road cover and make sure the tie downs are secure, check the tie down's for cuts fray's that could break in route. if your looking for a tool list, spare parts list if you make sure that the tires are in good shape, the lugs are torqued properly and the bearings are in good shape and packed with grease then you really don't need too many tools or spare parts and can worry a lot lease. But I guess to be safe than sorry, it might go like this. Spare hub, bearing, oil seal, spare tire, jack, wheel chalks, lug wrench, cotter pin, tools to change hub/bearings if needed. A lock for the trailer, spare bulb's/trailer lights. as Long as you go over the trailer and inspect everything and replace/repair as needed then you can sleep easy. Inflate the tires to the proper pressure before you leave. Double check all the lights are working you should be good to go. Oh and one last thing run the gas out of the tank on the boat no need to hual the extra weight all that distance and the gas prices might even be cheaper where your going. |
stang72
That does cover it !
We trail our boat quite a bit and do make some long trips ..so I'll add this...it's a good idea to make a couple early stops along the side of the road and feel the hubs for heat just to make sure all is well! Each time you gas or stop, do the same and look things over ...if it is all checking out ok you will feel more at ease as you travel along! Also..I tip my pitots up...I was told higher interstate speeds can blow too much air pressure through them. Tip your ski mirror down so the person behind you does not get a face full of sun shine! see ya there! |
jbear
You lucky dog; you are gonna have an awesome time!
john |
MaddMarxx
yeah if we make it! we are following "Reid" so we will probably all get lost! |
it's pretty easy to find Mark even with Reids disablities you should be all right but then again you are following Reid so all bets are off.
Mojo
MM, don't forget to register,, deadline has been moved to July 1... You'll be the 30th boat !!! Thanks Mojo... |
05' SV211 TE
MaddMarxx
Thanks mojo..I just got the boat in the diaries today, my next move is register tonite, I want to be #30, Blondie wants to register also so she can get all the stuff, is that ok?
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5766 |
Mark, just register her as a guest, each person you register under your listing will get a shirt and hat. |
jbear
So.....if I register as a guest...even tho I can't make it...I can get a hat and shirt?
john |
Yea is there a Swak only regestration?
jbear
Ok I give...what is SWAK?
Might be sorry I asked but..... john |
BlondieGurl1443
Senior Member Joined: August-20-2006 Location: United States Status: Offline Points: 150 |
Hey guys, do i need to register b/c i want a banner with my name on it and a ballot to judge the boats also? i think i deserve that! I will have a boat of my own soon, and it will be pink and black!!!! Just let me know, thanx!
stang72
BloodieGurl...pink and black?
Now if it was me...and I was a girl(which I'm not , but with enough cash and modern technology, I could be if I chose...which I would'nt cause I'm set in my ways.)I would go black hull with pink graghics with some silver metal-flake outlining the lettering! That is IF I was a gurl which as I already stated...I'm not...so do anything you want! Just a thought! |
free sh*t |
I think more people might know it as SWAG.
Mojo
Blondie, Typical, typical, want, want, want hahaha.. Well you can register and pay $25 bucks for a ballot, get a hat and shirt, or as a guest under MM and get the same stuff for $10, less the ballot... Banners ??? there's a Kinkos in Ripon that might be able to help you with that??? Please tell me you're not a vegitarian?? Moj' |
05' SV211 TE
jbear
Moj: She's not. She is awesome cool....not your usual blonde. Remember the pics of her in my boat scrapping gaskets?
john |
The Lake
Platinum Member Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
EDIT: I meant to put this under a different thread--sorry! |
Mojo
John, No dispersions from me, I meant it literally, because our sandwiches on Sat were going to have meat on them. haha.. It was more of a women/complaining thing.. Oh never mind Moj' Blondie, can't wait to meet ya.. Any women that scraps gaskets is alright in my book !!! see and look, not even a reference to the lime green bikini hahaha |
05' SV211 TE
67nautique312
Gold Member Joined: June-23-2004 Location: United States Status: Offline Points: 883 |
Bloniegurl,
Are you comming up with MM and Reidp? If so can't wait to meet Ya and i want a picture of you on my boat! That's the only way my boat will look better than Reid's and MM's boats! |
67 Riviera 68 barracuda 1971 Ski Nautique Promo 86 Silver Nautique 1995 Ski Nautique |
Mojo
Paul,
The only way your boat would look better, is if it were sitting in my driveway !!!! Moj' |
05' SV211 TE
67nautique312
It will be in your driveway that weekend moj remember......Are you Drunk? lay off the sauce moj
Maybe we could get a picture of Blondiegurl on my boat in your driveway? See ya soon!! Paul, |
Mojo
Permanently Paul.... Yeah I remember the arrangement.. I have 2 brain cells left to at least remember that.... Oh and do you want to see me in the doghouse all weekend??? Moj' |
05' SV211 TE
67nautique312
No dog house for you except the one on your Nautique......Oh and by the way Your boat is soooookick ass.....man that thing is clean!! whoever had that thing must have really taken care of it?
Almost G-day! |
Mojo
Thanks for the comps Paul, but like most of these boats (they look great at 20 feet) hahaha.. She runs out good, and gives my Kids the biggest smiles, so that's what matters most.. Can't wait for GL.. Hope the weather's as nice as last year....
Moj' |
05' SV211 TE
jbear
Now that is a cool visual: Blondie as a "Hull Ornament" on your boat, Paul. Thats gotta be the only way you could improve the looks of that awesome boat.
Bet your Dad wouldn't mind sitting next to her! Man....I just cannot wait for all the pics from GL! john |
MaddMarxx
Replaced all the bearings today, bought new trailer locks, and I have 2 spear tires for the trip...Whats next??..this better be fun, because.. danm, it sure is alot of work, I feel your pain...Reid..
jbear
Hey Mark; Great day. As always, thanks to you and Keith. Now my boat steers like new. What would we do without our own personal mechanic? We need to help him get his boat readt for the Orlando Reunion. When we got home...almost no rain here. Some storm there tho. Thanks again.
john |
Barracuda
MM- Make sure you have a locking PIN for your receiver hitch slug as well- remember that guy who's boat was stolen outside Chicago? The day I read that post, I drove to Walmart and bought a lock.
One peice of advise when trailering anything- don't watch it in the mirror- that will just make you nervous- Safe travels to you, Blondie, and eveeryone else making the trek to GL -Brad |
