  New Posts New Posts RSS Feed - Wiring Question
Wiring Question
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: Wiring Question
    Posted: June-27-2007 at 3:40pm
I am adding an additional Amp and a couple Tower Speakers to the factory system, with that thinking about possibly adding an additional battery up under the bow seats should it become necessary. My question is if adding a second (house) battery (about a 10'-12' cable run from the factory (starting) battery) what guage wire/cable should be used?
The stereo amps are 320watts and 800watts which would then come off the house battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 3:52pm
Chris, I feel it should be sized to the output of the alternator since that will be the max amps the wire will see. You however have the breaker so it wouln't need to be any bigger that it's rating. What is the output of your alternator and the size of the breaker?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 4:12pm
Assuming you have a 100A alt, 6awg wire would be able to handle that amount of current. However, if you ever plan to start the boat off the 2nd battery (in the event the starting battery is dead) you'll want bigger wiring than that. I would use 2awg or 0awg between the 2 batteries.
For the wiring from the 2nd battery to the amps, the worst case (max load) would be 1120W/12V=93A. A 6awg wire could handle 93A, then split to 8awg (800W/12V=67A) for the larger amp and 12awg (320W/12V=27A) for the smaller amp. Those would be minimum recommendations- I would probably use 4awg or 2awg as the main feed, then split to 4awg or 8awg for the 2 amps.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 4:36pm
Whatever ya need Chris, just get it done before GL will ya ??? hahaha We need tunes... I'll bring the jumper cables !!!
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 6:30pm
Quinner, I did this exact same mod to my boat. I used a 6 AWG cable from the 2nd Alt (100 AMp) to the "house batt" and put an 80 amp circuit breaker in line. My 2nd batt is powering 2 amps (each are at least 400 watts RMS) with a 2 farad capacitor in parallel. The 2 batteries are isolated from each other on the B+ side. I felt that this was important since every diagram that I came across for a 2 alternator setup used an isolator (expensive) between the two alternators. Since the 2 alternators are not exactly matched for their regulated voltage output, they must be isolated so that they are not fighting each other while charging. For starting emergencies you can tie the two batteries together on the B+ side with a battery disconnect switch and 0 AWG cable
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 7:01pm
Is that the only load on the 2nd alternator? If so, why effectively limit a 100A alt to 80A? I see the 80A breaker is necessary to protect the 6awg wire, but why not use a larger wire (4awg)? I assume you placed the breaker at the end of the wire closer to the battery?
Quinner's looking to do something a little different since hes considering adding a second battery, but not a second alt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2007 at 8:41pm
Yes the amps are the only load on the 2nd alternator and battery. I decided to err on the side of caution with the 80 Amp breaker because I never want to load the 2nd alt to full capacity. The two amps operating at max volume would never pull 80 amps from the alternator unless something is grossly wrong. The breaker is very close to the 2nd alternator.
This system has worked perfectly for me with no charging, starting or sound system problems since its install.
Former boats:
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 4:35am
run "0" awg for the pos and neg leads from the battery switch to the battery however long or short that maybe. Otherwise you cannot use that battery as a back-up starting battery either solo or in conjunction with the other battery.
From the bat to the amps 8-10 awg should be more than enough check the owners manual for the amps and see what they state. The amp I used specified the minimum gauge wire to run to the power leads of the amps.
what ever you do don't run some skinny ass 4 awg or smaller wire unless you realy are look for the insurance company to buy you a new boat because you will melt the wires and start a fire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 5:29am
The 4 AWG cable is the charging circuit (from the 2nd alt to the 2nd batt). Right now I do not have my 2nd battery connected as a backup starting battery. If you want to connect the two batteries for emergency starting, 0 AWG or larger with a battery disconnect is the way to go. I stated this in one of my posts above.
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 5:38am
I wasn't addressing your set up do what you want. I don't believe Chris is adding a second alternator only a second battery. And personally I would have never added a second alternator to start with just a larger alternator with higher output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 1:06pm
Thanks for the thoughts, I am going to take a look at what ga. the factory cables are and survey for the best spot for the second battery tonight and work from there.
The factory wire to the 320w amp is 8ga, I am pulling 4ga to the new 800w amp and my thought was if that 4ga would adequately support a second battery the run I am pulling now could be used as the battery run at a later date should the battery end up in the bow area. Not sure where the second battery would work out best, couple options are up under the bow, under the passenger seat area or in the floor cooler/storage area just in front of the existing battery box. Tim also suggested running the heavy ga. now to a fused dist block and then the amps from there, another good thought. Like the idea of the battery in the bow so the weight has a positive effect on the wake, then again like the floor storage location so the cable runs are not so long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 2:47pm
Chris, Glad you got it figured out. One thing for sure on this site, that when you ask a simple question, you end up with instuctions on how to build a rocket ship!!
I would lean towards the front location of the battery as well. The wire run will not be that much longer and as long as it's sized correctly will not make a difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2007 at 11:24pm
you have to ask your self one question. do i want to use this second bat to start the boat? if so then the 4 ga isn't going to get it done and if you are then the further away you get the larger the wire needs to be.
Working days next week Chris maybe we could get together Sunday evening or monday night. e-mail your numbers again had to replace the phone and don't have it anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2007 at 9:29am
Upon further review the only place an additional battery will fit easily and upright is the floor storage area. For the 4ga amp power/ground I plan on following the same route as the factory did with the 8ga. Getting from the battery box under the floor and up behind the kick panel will be the most challenging part and after that it should be no problem.
JR_VIC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR_VIC Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2007 at 3:20am
I have posted this before so you may have already read this thread before but I I did a complete stereo install on my 92 SNCB last September and it was an extensive install. As you can see in the pics we used "0" gauge wire for the connection from the battery combiner over to the second battery and also to an added ground block up under the driver's area right below the dash. I agree with 79 that you need at least "0" gauge wire if you are going to use the second battery as a starting battery if necassary. My installer also stated that to do it correctly it must be "0" gauge. I installed the Xantrex battery combiner and I think it is awesome. They are about $100 but are completely automatic with a manual switch you can push over in an emergency that combines both batteries for extra starting power. It has adjustable switches that you can set for example if it gets 11.5 volts from the alternator it automatically combines both batteries for charging and extra juice. As soon as you turn off the engine and no volts are present, it automatically disconnects the batteries so your starting battery is always hot. Again, I love it because everything is completely automatic with nothing to forget regarding switches like Perko that have to be manually switched on/off/1 battery/2 batteries etc. Here are some pics and hope that helped. Boat was extremely dirty in these pics...shame on me!
"That's not a Snow Cone that's my Ring!"
