Tight steering to the right |
Tim D
Posted: July-29-2007 at 1:17am |
All of the sudden my steering is tight to the right, sometimes stops in a certain spot, unless you turn it back to the left a little, then it frees up. It turns fine with no resistance to the left. Is the steering cable worn out?
Tim D
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
that's my experience.
Mullet Free since 93
95 Sport |
boat dr
Sounds more like the helm assy,the cable could be at fault also.........
Steering systems are cheap / crashes are not.........boat dr |
behindpropeller
Mine did that for an hour. Then the cable broke. FYI.
Tim D
I see that since I have the orginal white cable, I have to buy a clevis kit. Does that part connect to the rudder?
Tim D
jeffinohio
Newbie Joined: July-07-2006 Location: Madison, Ohio Status: Offline Points: 26 |
it may not be the cable. mine did exactly the same thing. left turns ok, right hard. there is a grease fitting on the rudder assembly under the gas tank area. that did the trick. turns great both ways now. i bet this will fix the problem.
The grease fittings were only put on in latter years. Does anyone know the year? |
jeffinohio
mine is a 1992
Tim D
Mine is 66.
Tim D
