Rattling noise from gearbox |
Michel
Newbie Joined: June-02-2007 Location: Netherlands Status: Offline Points: 28 |
Posted: July-29-2007 at 10:13am |
When I shift from neutral idle to forward- or reverse idle (650 RPM), I hear a strange rattling noise probably coming from the gearbox.
When I increase RPM to about 800 or higher, the noise dissapears. Is this a gearbox which is going to crash soon, or has somebody an idea what it could be? Thx, Michel |
BuffaloBFN
Look for Eric's posts on rough idle...that could be all it is
Michel
Thanks for the replies.
(Dont hope that the damper plate is bad though...) Is it also possible that the gear-shift-cable is not properly adjusted? Michel |
BuffaloBFN
I'm not the expert here, but it sounds like the plate if your motor and idle are soild
it'll take a few, but read through Eric's alignment thread |
Michel, A shift cable that is out of adjustment will simply cause the trans not to shift when it is supposed to. |
