Is the alternator O.K. |
dmc346
Newbie Joined: June-26-2007 Location: United States Status: Offline Points: 35 |
Posted: August-04-2007 at 1:16am |
The volt meter on my 1994 SN sport reads 15-16 volts at all times (at idle or full throttle) is this too high, and if so what is the problem.
Thanks Dave |
dmc346
stang72
Dave ,
Thats too high...but, it may not read the same as the real output from the alternator. Check the voltage with a voltage meter at the battery when the boat is running at idle...you should see between 13.5 and 14.5 volts. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Yup, first check with a DVM, the gauges are notoriously unreliable.
River Rat to Mole |
dmc346
Thanks, I will try with a meter in the morning and let you know.
Dave |
dmc346
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Dave, if it reads that high with a DVM then you need a new alternator. The voltage regulator (internal) is not doing its job. But before you replace anything make sure all connections on the back of the alternator are tight. Brian
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
dmc346
Tested at the battery with a DVM and it read 13.94 volts. I would have to say the gauge at the dash is way off. Thanks for the help and suggestions.
Dave |
dmc346
