  New Posts New Posts RSS Feed - Lighting up Airguide Speedo?
Nautique Mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautique Mike Quote  Post ReplyReply Direct Link To This Post Topic: Lighting up Airguide Speedo?
    Posted: August-05-2007 at 11:37am
Hey Gang-
I was curious if anyone has figured out a way to put a viewing light in the Aiguide 725 Speedo(I think that's the model #)? I have two original ones on my 78'SN and it would be sweet to see them @ night. I'm no electrical wizard so ideas on hooking them up would also be a help.
Thanks-
NM
Nautique Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2007 at 2:19pm
Mike, This is a post over on "the" site about converting gauge lighting to LED's. Its interesting but don't think it will help you much. The gauge really needs to be designed and build to be lighted to start. Back lighting is done with a semi-transparent face. Front lighting needs the light source to come out around the perimeter of the face but then be reflected back onto the face by a reflective surface usually behind the benzel.
LED conversion
What do you want to do? Some night skiing?
