  New Posts New Posts RSS Feed - The motor in my mustang is hosed
colinc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colinc Quote  Post ReplyReply Direct Link To This Post Topic: The motor in my mustang is hosed
    Posted: September-06-2004 at 6:19pm
I attempted to start my mustang today and couldnt get it to fire - the motor seemed to be turing over a little too easily so I got out the compression tester and found that it has like 50 to 90 psi on all the cylinders.
Damn.
So I have options:
A) Rebuild the original 260 thats in the boat.
B) Find a decent running 289 or 302 from a car/truck, and convert it to reverse rotation re-using the appropriate parts from my 260 (the cam is the important part right?)
c) Spend all the money and buy a crate motor that is already set up for reverse rotation bolt on my interceptor parts
What do you guys think?
-Coop
yellowdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2004 at 7:48pm
A. If mine and I was happy with the performance of the 260, I would rebuild it.
B. Trying to convert a standard rotation to right hand is more than the cam. I understand that the journals on the crank are machined differently and there are a few other "hidden" changes. Not something I would care to tackle without a whole bunch more knowledge. Not that I am afraid of a rebuild, more like I would hate to spend all those hours doing the work and then watching it meltdown because I overlooked some $0.50 detail like a right-handed oil pump bearing or something equally 'minor'.
C. Probably the most costly, but you do get a warranty of sorts???
Let us know how it goes.
Caretaker of the wife's '78 Ski Nautique
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2004 at 1:57pm
How many hours does the engine have on it. I'd pull the heads before I decided. You may be able to get away with just a valve job.
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2004 at 5:23pm
My 2 cents is to re-build. You have a lot of options...go original...stroke...performance cams, intake etc without the hassle of accessories, mounts etc not working.
I agree with Rick, and add that you may want to leak test to see if it's rings or valves...most likely valves.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2004 at 5:04pm
A 260 has a smaller bell housing bolt pattern than a 289 and 302. I found this out when I changed from a 260 to a 302.
Tim D
