back fire through carb under load |
Stevt
Newbie Joined: August-13-2007 Status: Offline Points: 5 |
Posted: August-17-2007 at 7:01pm |
I have a 68 mustang with a 302,in the yard in neutral it runs fine,revs up and sounds great. In the lake when I took off it backfired through the carb and stalled. I tried to adjust the distrubtor in the water and got it running back to the ramp. I think it's a timing problem, does anyone know what the timing should be and at what RPM'sor any other suggestions?
Tim D
Replace the power valve in the carb if it backfired through the flame arrestor. And change the accel pump too.
Tim D
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Backfiring through the carb can be caused by a couple of different things. The most likely cause is a lean air/fuel mixture. With the age of your boat I wouldn't be surprised if your backfire was isolated to a worn camshaft (lobe wiped off). Especially with oils that are available today. Timing can cause backfires too but that usually occurs in the exhaust.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
79nautique
accel pump and timing
backfoot100
To answer your original question. Not positive about a 302 timing but I know that a 351 or a 350 will be 8 degrees BTDC at 600-700 RPM. I would assume that a 302 would be about the same. Start there and see how it does.
Eddie |
Stevt
Thanks all for the advice, it's 6:30am and I'm ready to go try a few differnt thing's (my wife thinks I'm nuts). This site is great and I'm glad I found it. The only other older Correct Craft in my area is "Hot Pant's" and I told him yesterday about this site. He was driving down the road when he saw a Correct Craft go by and had to turn around and follow it to the ramp. We talked and he watched as me and my son took off,then he watched as I putted back to the ramp. I need to get this thing running right ! Thanks
