amp/fuse problem |
Guests
Guest |
Posted: September-02-2007 at 5:24pm |
one of the 15 amp fuses on my subwoofer amp keeps popping..i checked the headunit wires, main 100 amp inline fuse, and think everything is tight..never had a problem with it until today..worked fine yesterday when i was out..i even tried a 25 amp fuse and it blew it also..seems like whenever i turn the headunit on it blows immed. my four channel amp is still working with no problems...could it be a bad inline fuse holder? maybe the amp took a sh*t?..any ideas what would be causing this?..
Guests
Guest |
anyone?
882001
Senior Member Joined: October-21-2003 Location: United States Status: Offline Points: 332 |
sounds like a bad sub amp to me
kemah texas
1988 skinautique "2001" |
Randy_in_Ohio
Ryan,
Good talking to you earlier, let me know how you come out, if you need help give me a call. |
Guests
Guest |
randy.....zero luck
Guests
Guest |
still making funny noises, amps totally disconnected
